coq-club - Re: [Coq-Club] coqtop on theories files?
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Pierre Courtieu <pierre.courtieu AT gmail.com>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] coqtop on theories files?
  • Date: Tue, 4 Sep 2012 17:14:59 +0200
Thank you Hugo it works like a charm.
Regards,
Pierre
2012/9/3 Hugo Herbelin
<Hugo.Herbelin AT inria.fr>:
> Hi Pierre,
> I guess that what you are looking for is
> coqtop -top Coq.Classes.Morphisms
> This sets the toplevel module name to be "Coq.Classes.Morphisms"
> instead of the default "Top". Then, the lemmas defined in Morphisms
> and referred to with their expected qualified name in the setoid
> rewriting tactic, which itself is called from Morphisms.v, will be
> correctly identified (when using "Load Morphisms").
> Hugo
> On Mon, Sep 03, 2012 at 05:13:03PM +0200, Pierre Courtieu wrote:
>> Hello,
>> While experimenting things on theories files I did not manage to
>> script files like this one:
>> theories/Classes/Morphisms.v
>> This looks like a bootstrapping problem of the rewrite tactic.
>> At line 364 I have this error:
>> respectful_morphism < rewrite <- H0.
>> Toplevel input, characters 0-13:
>> > rewrite <- H0.
>> Error: Library Coq.Setoids.Setoid has to be required first.
>> Obviously the rewrite tactic called here is not he right one because
>> it depends on morphisms.
>> Running coqtop -boot does not solve the problem.
>> However:
>> coqtop -boot -compile theories/Classes/Morphisms.v
>> does compile the file (this is the way it is compiled when building coq).
>> Can someone tell me the correct coq invocation to start coqtop in
>> interactive mode on this file please?
>> Regards,
>> Pierre Courtieu
