- To: Robert Dockins <robdockins AT fastmail.fm>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] fixpoint nested inside cofixpoint
- Date: Tue, 18 Sep 2012 09:59:14 +0200
Hello Robert,
your definition looks fine, but it is known that the guardedness check is quite incomplete. Sorry, I cannot help here, but out of curiousity I ported your definition to Agda and there it is accepted.
module GraphSpanningTree (I : Set) where
open import Coinduction
open import Data.List using (List; []; _∷_; map)
-- Graph as adjacency list
Graph = I → List I
data SpanningTree : Set where
span : ∞ (List SpanningTree) → SpanningTree
module Mutual (g : Graph) where
mutual
graphToSpan : (root : I) → SpanningTree
graphToSpan root = span (♯ (mapAdj (g root)))
mapAdj : List I → List SpanningTree
mapAdj [] = []
mapAdj (i ∷ is) = graphToSpan i ∷ mapAdj is
Cheers,
Andreas
On 16.09.12 9:19 PM, Robert Dockins wrote:
I'm playing around with representations for graphs, and I've run into difficulty
stating a definition I want. I'd like to prove some results relating graphs
represented via successor lists to a representation via an infinite "spanning
tree," but Coq will not accept a cofixpoint definition that seems productive to
me. The following is a simplified form. Coq 8.3pl1 and 8.4 give the same error
(reproduced below).
I think this definition ought to be accepted, but it runs afoul of the
guardness checker. Apparently you cannot have fixpoints nested inside
cofixpoints? Is there any nice way to get around this?
Thanks,
Rob Dockins
Require Import List.
Record graph (I:Type) := { succ_list : I -> list I }.
CoInductive spanning_tree :=
| span : list (spanning_tree) -> spanning_tree.
CoFixpoint graph_to_span I (G:graph I) (root:I) : spanning_tree :=
span ((fix f (l:list I) : list spanning_tree :=
match l with
| nil => nil
| i::is => graph_to_span I G i :: f is
end)
(succ_list I G root)).
Coq responds:
Error:
Recursive definition of graph_to_span is ill-formed.
In environment
graph_to_span : forall I : Type, graph I -> I -> spanning_tree
I : Type
G : graph I
root : I
Sub-expression "(fix f (l : list I) : list spanning_tree :=
match l with
| nil => nil
| i :: is => graph_to_span I G i :: f is
end) (succ_list I G root)" not in guarded form (should be
a constructor, an abstraction, a match, a cofix or a recursive
call).
Recursive definition is:
"fun (I : Type) (G : graph I) (root : I) =>
span
((fix f (l : list I) : list spanning_tree :=
match l with
| nil => nil
end) (succ_list I G root))".
Andreas Abel <>< Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
- [Coq-Club] fixpoint nested inside cofixpoint, Robert Dockins, 09/16/2012
- Re: [Coq-Club] fixpoint nested inside cofixpoint, Andreas Abel, 09/18/2012
- Re: [Coq-Club] fixpoint nested inside cofixpoint, Chung-Kil Hur, 09/18/2012
- [Coq-Club] Re: fixpoint nested inside cofixpoint, Dimitur Krustev, 09/18/2012
