- To: coq-club AT inria.fr
- Subject: [Coq-Club] Re: fixpoint nested inside cofixpoint
- Date: Tue, 18 Sep 2012 21:31:31 +0000 (UTC)
Robert Dockins <robdockins <at> fastmail.fm> writes:
> I'm playing around with representations for graphs, and I've run into
difficulty stating a definition I
> want. I'd like to prove some results relating graphs represented via
successor lists to a representation
> via an infinite "spanning tree," but Coq will not accept a cofixpoint
definition that seems productive to
> me. The following is a simplified form. Coq 8.3pl1 and 8.4 give the same
error (reproduced below).
> I think this definition ought to be accepted, but it runs afoul of the
guardness checker. Apparently you
> cannot have fixpoints nested inside cofixpoints? Is there any nice way to
> get
around this?
> Thanks,
> Rob Dockins
Hi Robert,
When I recently stumbled upon a similar problem, I found the ideas from the
following paper useful:
- C Picard, R Matthes, "Mixing induction and co-induction in Coq: a case
study
for lists", 2010
Briefly, the main trick is to avoid mixing induction and co-induction
altogether: replace the nested use of the inductive [list] with an isomorphic
non-inductive definition, such as [fun A => { length: nat & Fin length -> A
(using your favorite definition of [Fin]). The advantage is that many
functions
(especially [map]) have non-recursive definitions for this version of finite
lists, which makes it easier for Coq to "see" that certain co-inductive
definitions are productive.
I am not sure how well this would work in your particular setting, but it
might
be worth to try.
Best regards,
Dimitur
- [Coq-Club] fixpoint nested inside cofixpoint, Robert Dockins, 09/16/2012
- Re: [Coq-Club] fixpoint nested inside cofixpoint, Andreas Abel, 09/18/2012
- Re: [Coq-Club] fixpoint nested inside cofixpoint, Chung-Kil Hur, 09/18/2012
- [Coq-Club] Re: fixpoint nested inside cofixpoint, Dimitur Krustev, 09/18/2012
