coq-club - Re: [Coq-Club] Decision procedures in Coq
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Decision procedures in Coq
  • Date: Fri, 28 Sep 2012 19:03:05 +0200
Am 28.09.2012 18:18, schrieb AUGER Cédric:
Given a type X:Type and a predicate P:X→Prop, a decision procedure is
some function of type ∀ x, {P x}+{¬P x}.
I was interested in a simpler thing, that is some procedure of type ∀
x, {P x}+unit (that is that you do not care to prove that your property
is wrong). I do not know how would be called such a procedure
(semi-decision procedure wouldn’t fit as it stands for something
slightly different, let us call that a half-decision procedure. If you
have a better name, let me know, I would be interested).
Basically you have two special cases, the not very interesting one
defined by "λ x, right tt" (so you always say 'wrong') and the most
interesting one (or an extensionnaly equal one) "λ x, match f x with
left π => left π | right π => right tt end".
So I was wondering what criterion would be good to say which ones are
good and which ones are bad. I thought that if you have the following
property: "∀ x, P x → ∃ π, f x = left π" where 'f' is my half-decision
procedure. I thought that if a function 'f' verifies this property,
then I could classically prove that it is a decision procedure. In fact
it ended up that this is even intuitionistically provable. But in
practice, I have the feeling that when P is some big inductive type, it
easier to build a half-decision procedure and prove that it verifies
our property than to directly write the decision procedure.
I lack some experimentation with "half-decision", so my feelings may be
wrong. But when I used to try the direct approach, it occured that all
those "¬P" I encountered in goals and hypothesis were a little annoying.
Require Import Utf8.
Definition Pred X := X → Prop.
Inductive dec {X} (P : Pred X) (x : X) : Type :=
| Ok : P x → dec P x
| Ko : ¬ P x → dec P x
Inductive sdec {X} (P : Pred X) (x : X) : Type :=
| Yes : P x → sdec P x
| No : sdec P x
Definition Strong_sdec {X} {P : Pred X} (f : ∀ x, sdec P x) :=
∀ x, P x → ∃ π, f x = Yes P x π.
Definition strengthen_dec {X} {P : Pred X} (f : ∀ x, sdec P x)
: Strong_sdec f → ∀ x, dec P x
:= λ H x, match f x as y return (P x → ∃ π, y = Yes P x π) → dec P x
with | Yes π => λ _, Ok P x π
| No => λ H, Ko P x (λ K, match H K with ex_intro π ρ =>
match ρ with eq_refl => True
end end)
end (H x).
If you can prove that property, then you also have:
∀ x π, f x = right π → ¬P x
And obviously you have
∀ x π, f x = left π → P x
(since π : P x)
I guess this is a proof why semi-decidable problems can not be decided by
semi-decidable procedures in coq (I'm sticking to your terminology here).
I have not worked with this approach myself, but I assume that proving the
lemma takes about as much sweat as proving the decision procedure.
Kind regards, jonas
