coq-club - Re: [Coq-Club] Decision procedures in Coq
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Decision procedures in Coq
  • Date: Fri, 28 Sep 2012 22:29:00 +0200
Am 28.09.2012 19:55, schrieb AUGER Cédric:
Le Fri, 28 Sep 2012 19:03:05 +0200,
Jonas Oberhauser
<s9joober AT gmail.com>
a écrit :
Am 28.09.2012 18:18, schrieb AUGER Cédric:
Given a type X:Type and a predicate P:X→Prop, a decision procedure
is some function of type ∀ x, {P x}+{¬P x}.
I was interested in a simpler thing, that is some procedure of type
∀ x, {P x}+unit (that is that you do not care to prove that your
property is wrong). I do not know how would be called such a
procedure (semi-decision procedure wouldn’t fit as it stands for
something slightly different, let us call that a half-decision
procedure. If you have a better name, let me know, I would be
interested).
Basically you have two special cases, the not very interesting one
defined by "λ x, right tt" (so you always say 'wrong') and the most
interesting one (or an extensionnaly equal one) "λ x, match f x with
left π => left π | right π => right tt end".
So I was wondering what criterion would be good to say which ones
are good and which ones are bad. I thought that if you have the
following property: "∀ x, P x → ∃ π, f x = left π" where 'f' is my
half-decision procedure. I thought that if a function 'f' verifies
this property, then I could classically prove that it is a decision
procedure. In fact it ended up that this is even intuitionistically
provable. But in practice, I have the feeling that when P is some
big inductive type, it easier to build a half-decision procedure
and prove that it verifies our property than to directly write the
decision procedure.
I lack some experimentation with "half-decision", so my feelings
may be wrong. But when I used to try the direct approach, it
occured that all those "¬P" I encountered in goals and hypothesis
were a little annoying.
Require Import Utf8.
Definition Pred X := X → Prop.
Inductive dec {X} (P : Pred X) (x : X) : Type :=
| Ok : P x → dec P x
| Ko : ¬ P x → dec P x
Inductive sdec {X} (P : Pred X) (x : X) : Type :=
| Yes : P x → sdec P x
| No : sdec P x
Definition Strong_sdec {X} {P : Pred X} (f : ∀ x, sdec P x) :=
∀ x, P x → ∃ π, f x = Yes P x π.
Definition strengthen_dec {X} {P : Pred X} (f : ∀ x, sdec P x)
: Strong_sdec f → ∀ x, dec P x
:= λ H x, match f x as y return (P x → ∃ π, y = Yes P x π) → dec P x
with | Yes π => λ _, Ok P x π
| No => λ H, Ko P x (λ K, match H K with ex_intro π ρ =>
match ρ with eq_refl => True
end end)
end (H x).
If you can prove that property, then you also have:
∀ x π, f x = right π → ¬P x
I guess you mean "∀ x, f x = right tt → ¬P x"
(or "∀ x, f x = No _ _ → ¬ P x" with my example)
I do not think this matters since∀ π : unit, π = tt
But I believe my formulation could save you a destruct here and there.
And obviously you have
∀ x π, f x = left π → P x
(since π : P x)
I guess this is a proof why semi-decidable problems can not be
decided by semi-decidable procedures in coq (I'm sticking to your
terminology here).
I used "half" rather than "semi" in order to avoid confusion.
Oh, my bad. It appears I accidentaly reversed your terminology. I meant half-decision procedures of course.
I have not worked with this approach myself, but I assume that
proving the lemma takes about as much sweat as proving the decision
procedure.
I think it cannot really be a lot harder, but proofs can be quite
different in appearance.
Using my previous definitions:
Definition list_dec1 {A} (d : ∀ (a b : A), {a=b}+{a≠b})
: ∀ (l m : list A), dec (eq l) m.
refine (
fix ld l :=
match l as l return ∀ m, dec (eq l) m with
| nil => λ m, match m with
| nil => Ok _ _ eq_refl
| cons hm m => Ko _ _ _
end
| cons hl l => λ m, match m with
| nil => Ko _ _ _
| cons hm m => if d hl hm
then if ld l m
then Ok _ _ _
else Ko _ _ _
else Ko _ _ _
end
end
Proof.
clear; abstract (exact (λ H, match H with eq_refl => True end)).
Proof.
Proof.
clear - _H _H0;
abstract (exact (match _H with eq_refl =>
match _H0 with eq_refl =>
eq_refl
end end)).
Proof.
clear - _H0;
abstract (exact (λ H, _H0 match H with eq_refl => eq_refl end)).
Proof.
clear - _H;
abstract (exact (λ H, _H match H with eq_refl => eq_refl end)).
Defined.
Definition list_dec2 {A} (d : ∀ (a b : A), {a=b}+{a≠b})
: ∀ (l m : list A), sdec (eq l) m.
refine (
fix ld l :=
match l as l return ∀ m, sdec (eq l) m with
| nil => Yes _ _ eq_refl
| cons hm m => No _ _
end
| nil => No _ _
then if ld l m
then Yes _ _ _
else No _ _
else No _ _
end
end
Proof.
clear - _H _H0;
eq_refl
end end)).
Defined. (* only one proof here! *)
Lemma ld2strong {A} d (l:list A) : Strong_sdec (list_dec2 d l).
Proof.
intros m [].
induction l; simpl; auto.
repeat esplit.
destruct IHl; rewrite H; clear u.
destruct (d a a).
repeat esplit.
now destruct n.
Qed.
I know I didn't use powerful tactics, and I know of "decide equality",
"discriminate", "inversion" and all that stuff. In this case, I think I
could provide one line tactics, but I do not care of it. For me, the
two approaches are different. The second one doesn't have to deal with
so many "…→False".
The two approaches are different, but how much work does it save you? Of course you could argue that the "…→False" are the annoying part of the proofs, in which case this approach could be certainly interesting. I mean, this type is inhabited:
"forall X (P : X -> Prop) (f : forall x : X, P x + unit) (H : forall x, P x -> exists p, f x = inl unit p) x, {P x} + {~ P x}"
(sorry for not using the nice formatting that you do but I'm not familar with it yet)
Hence we can always use that second approach and get the same results anyway.
