- To: "gallais @ ensl.org" <guillaume.allais AT ens-lyon.org>
- Cc: Arthur Azevedo de Amorim <arthur.aa AT gmail.com>, coq-club AT inria.fr, "J. Ian Johnson" <ianj AT ccs.neu.edu>
- Subject: Re: [Coq-Club] Indices in mutual inductives
- Date: Fri, 5 Oct 2012 11:21:14 -0400 (EDT)
True, I had meant to say that the type was empty.
Generally, I think that think kind of definition should be okay, since the
non-strictly positive occurrence is "treated positively" in the same way that
the recursive structure of a closure might have a non-strictly positive
occurrence for the type of the dictionary's values, but due to the treatment
by the dictionary, this circularity must always bottom out.
concretely:
Inductive Value : Type :=
| closure : lambda-expr -> (dictionary Variable Value) -> Value
To make the metatheory work out, there need to be positivity annotations on
type arguments, but I haven't given much thought into the deeper meaning of
this (gotta graduate).
My high level feeling is that it should work, but it could make recursion
very hard to prove terminating (though would make many programming patterns I
use in daily life actually possible).
-Ian
----- Original Message -----
To: "J. Ian Johnson"
Cc: "Arthur Azevedo de Amorim"
Sent: Friday, October 5, 2012 11:10:49 AM GMT -05:00 US/Canada Eastern
Well, this is just saying that B is empty. But it's usually ok to
define empty sets!
Inductive B : Set :=
BIntro : B -> B.
Fixpoint omega (b : B) : False := match b with
BIntro b' => omega b'
end.
gallais
On 5 October 2012 16:00, J. Ian Johnson
wrote:
> Fixpoint omega (b : B) (a : A b) : False :=
> match a with
> | AIntro (BIntro b'' a') => omega b'' a'
> end.
> From: "Arthur Azevedo de Amorim"
> To:
> Sent: Friday, October 5, 2012 10:42:20 AM GMT -05:00 US/Canada Eastern
> Subject: [Coq-Club] Indices in mutual inductives
> Dear list,
> Coq rejects the following definition
> Inductive A : B -> Type :=
> | AIntro : forall b, A b
> with B : Type :=
> | BIntro : forall b (a : A b), B
> | Base : forall b, B.
> Is there any metatheoretical reason for this? Does anyone have an
> example showing that it would make the logic inconsistent?
> Thanks
- [Coq-Club] Indices in mutual inductives, Arthur Azevedo de Amorim, 10/05/2012
- Re: [Coq-Club] Indices in mutual inductives, Andreas Abel, 10/07/2012
- <Possible follow-up(s)>
- Re: [Coq-Club] Indices in mutual inductives, J. Ian Johnson, 10/05/2012
- Re: [Coq-Club] Indices in mutual inductives, gallais @ ensl.org, 10/05/2012
- Re: [Coq-Club] Indices in mutual inductives, Arthur Azevedo de Amorim, 10/07/2012
- Re: [Coq-Club] Indices in mutual inductives, J. Ian Johnson, 10/08/2012
