coq-club - Re: [Coq-Club] Indices in mutual inductives
  • To: Arthur Azevedo de Amorim <arthur.aa AT gmail.com>
  • Cc: "gallais @ ensl.org" <guillaume.allais AT ens-lyon.org>, coq-club AT inria.fr, "J. Ian Johnson" <ianj AT ccs.neu.edu>
  • Subject: Re: [Coq-Club] Indices in mutual inductives
  • Date: Sun, 7 Oct 2012 18:19:47 -0400 (EDT)
No, you're talking about negative occurrences always being bad. I'm talking
about a new dimension to types that would safely allow use in a negative
position. Some restriction to parametricity might make this legal. Really
this is a pipe dream from my frustrations with splitting out specification
and implementation only to learn that the type system doesn't have the
facilities for the kind of abstraction I need. Unfortunately I don't have a
completely formal solution yet, since this area of research is fairly
tangential to my current work.
-Ian
----- Original Message -----
To: "J. Ian Johnson"
Sent: Sunday, October 7, 2012 4:51:08 PM GMT -05:00 US/Canada Eastern
Yeah, the example wasn't very good; I just wanted to get the simplest
example that would work out.
On Fri, Oct 5, 2012 at 11:21 AM, J. Ian Johnson
wrote:
> True, I had meant to say that the type was empty.
> Generally, I think that think kind of definition should be okay, since the
> non-strictly positive occurrence is "treated positively" in the same way
> that the recursive structure of a closure might have a non-strictly
> positive occurrence for the type of the dictionary's values, but due to the
> treatment by the dictionary, this circularity must always bottom out.
> concretely:
> Inductive Value : Type :=
> | closure : lambda-expr -> (dictionary Variable Value) -> Value
> To make the metatheory work out, there need to be positivity annotations on
> type arguments, but I haven't given much thought into the deeper meaning of
> this (gotta graduate).
Doesn't this happen already? If a type parameter has a negative
occurrence, then Coq will forbid some uses of the inductive, like this
Inductive foo T := Foo : (T -> bool) -> foo T.
Inductive bar := Bar : foo bar -> bar.
This definition will correctly be rejected because T occurs negatively in foo.
> My high level feeling is that it should work, but it could make recursion
> very hard to prove terminating (though would make many programming patterns
> I use in daily life actually possible).
> -Ian
> From: "gallais @ ensl.org"
> Cc: "Arthur Azevedo de Amorim"
> <arthur.aa AT gmail.com>,
> Sent: Friday, October 5, 2012 11:10:49 AM GMT -05:00 US/Canada Eastern
> Well, this is just saying that B is empty. But it's usually ok to
> define empty sets!
> Inductive B : Set :=
> BIntro : B -> B.
> Fixpoint omega (b : B) : False := match b with
> BIntro b' => omega b'
> end.
> gallais
> On 5 October 2012 16:00, J. Ian Johnson
> wrote:
>> Fixpoint omega (b : B) (a : A b) : False :=
>> match a with
>> | AIntro (BIntro b'' a') => omega b'' a'
>> end.
>> From: "Arthur Azevedo de Amorim"
>> To:
>> Sent: Friday, October 5, 2012 10:42:20 AM GMT -05:00 US/Canada Eastern
>> Subject: [Coq-Club] Indices in mutual inductives
>> Dear list,
>> Coq rejects the following definition
>> Inductive A : B -> Type :=
>> | AIntro : forall b, A b
>> with B : Type :=
>> | BIntro : forall b (a : A b), B
>> | Base : forall b, B.
>> Is there any metatheoretical reason for this? Does anyone have an
>> example showing that it would make the logic inconsistent?
>> Thanks
