- To: AUGER Cédric <sedrikov AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Extraction and the use of Type vs Set in datastructures
- Date: Sat, 6 Oct 2012 14:35:15 +0200
On Sat, Oct 6, 2012 at 1:51 PM, AUGER Cédric
wrote:
> Le Sat, 6 Oct 2012 10:19:39 +0200,
> Petter Urkedal
> <paurkedal AT gmail.com>
> a écrit :
>> I can see the point of using Type in a parameter positions of general
>> purpose modules, and this seems to be the general design of the
>> standard library. So, is the idea that one should just switch to Type
>> whenever these are mixed into ones own data structures, even if they
>> could have been in Set from a logical point of view? I don't see a
>> problem with it if extraction works, it seems a bit radical to lift
>> whole developments to an unspecific universe.
> The extraction does not make difference between Set and Type. After
> all, OCaml, Haskell and Scheme do not care about universe
> inconsistencies (which is mainly why we have Set and Type in Coq).
> I would recommend to always use Type, and never Set. Or always use Set
> and never Type (for very simple developpements which could allow it).
> Mixing both is hardly ever a good idea. The only good points of using
> Set vs Type is to make coq perform less computations to solve universe
> constraints. But this part of the computation is often neglictable in
> regards to the other computations.
That's precisely what I needed to hear!
> Of course, it is okay to play with it and allows you to have a better
> of the mechanics. But once you know how it works, chose between make
> Coq do all computations (stick only to type) or make him do none (stick
> with Set, and if needed define some universe: Definition U1 := Type.
> Definition U2 := (Type : U1). and so on, which you will use instead of
> Type)
Nice tip, though I don't worry about leaving the inequalities to Coq.
Thanks,
Petter
- [Coq-Club] Extraction and the use of Type vs Set in datastructures, Petter Urkedal, 10/06/2012
- Re: [Coq-Club] Extraction and the use of Type vs Set in datastructures, AUGER Cédric, 10/06/2012
- Re: [Coq-Club] Extraction and the use of Type vs Set in datastructures, Petter Urkedal, 10/06/2012
