- To: coq-club AT inria.fr
- Subject: [Coq-Club] refine skipping hole
- Date: Sat, 06 Oct 2012 11:17:09 -0700
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
To learn about accessibility and well-foundedness,
I tried to prove that the Ackermann function is well-founded.
I'm using "Coq 8.3pl1 (July 2011)". (Yes, I know that I can
just write it using 2 fixes.)
I wrote the program at the bottom of this message.
However, when I go to prove the ack_step function
(in the comment at the bottom), I leave 2 holes.
However, refine only adds the 2nd as an obligation,
skipping the first. How do I manually add an
Existential as an Obligation?
I tried many variations of
Focus Existential 1.
Focus ?45.
etc.
but none of them allow me to go to it.
Why is it skipped?
How do I Focus on it?
Ackermann function.
Attempt showing well-foundedness with the Ackermann function,
even though nest recursion handles it directly.
I am having a problem with refine skipping a hole.
How do I go to the hole explicitly?
Definition ack_ord (p q : nat*nat) :=
let (a1, b1) := p in
let (a2, b2) := q in
a1 < a2 \/ (a1 = a2 /\ b1 < b2)
Theorem le_Sn_0 n: S n <= 0 -> False.
intros.
inversion H.
Qed.
Theorem le_S_both a b: a <= b -> S a <= S b.
intros.
induction H.
apply le_n.
apply le_S.
apply IHle.
Qed.
Theorem le_0 a: 0 <= a.
induction a.
apply le_n.
apply le_S.
apply IHa.
Qed.
Theorem ack_wf_b: forall a, Acc ack_ord (a, 0) -> forall b, Acc ack_ord (a,
b).
intros.
induction b.
apply H.
apply Acc_intro.
induction y.
intros.
induction H0.
apply (Acc_inv IHb).
apply or_introl.
apply H0.
induction H0.
rewrite H0.
clear H0 a0.
inversion H1.
apply IHb.
apply IHb.
apply or_intror.
apply conj.
apply eq_refl.
apply H2.
Qed.
Theorem ack_wf: well_founded ack_ord.
unfold well_founded.
induction a.
apply ack_wf_b.
clear b.
induction a.
apply Acc_intro.
induction y.
intros.
induction H.
apply le_Sn_0 in H.
apply (False_ind _ H).
induction H.
apply le_Sn_0 in H0.
apply (False_ind _ H0).
apply Acc_intro.
induction y.
intros.
apply ack_wf_b.
induction H.
inversion H.
apply IHa.
apply (Acc_inv IHa).
apply or_introl.
apply H1.
induction H.
Qed.
Theorem ack_step x (f : forall y, ack_ord y x -> nat) : nat.
refine (
match x as z return x = z -> nat with
| pair a b => fun H =>
match a as c return a = c -> nat with
| 0 => fun _ => S b
| S a0 => fun H2 =>
f (
a0,
match b as d return b = d -> nat with
| 0 => fun _ => 1
| S b0 => fun H3 => f (a, b0) _
end (eq_refl b)
) _
end (eq_refl a)
end (eq_refl x)
(* Skips first hole for f (a, b0) _ *)
(* 2nd hole *)
rewrite H.
rewrite H2.
apply or_introl.
apply le_n.
(* Can't save, how do I go back to first Existential hole? *)
No more subgoals but non-instantiated existential variables:
Existential 1 =
?56 : [x : nat * nat
f : forall y : nat * nat, ack_ord y x -> nat
a : nat
b : nat
a0 := a : nat
b0 := b : nat
H : x = (a, b)
a1 : nat
a2 := a1 : nat
H2 : a0 = S a1
b1 : nat
b2 := b1 : nat
H3 : b0 = S b1 |- ack_ord (a0, b2) x]
$_="sccc,gB1,a_oo,JosBackuSa,g11,ug1a,oscc,cBBg,JcgaBuucaB_s11_Juc_c";
while(($c,$b,$a)=m/^(.)([^,]*),(.*)$/){$_=$a;s/$c/$b/g;}
print map chr length,split /_/;
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.17 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlBwdaUACgkQxzVgPqtIcfuU9ACfZK3zfxqINhYXXcpIGPelB/ML
FYYAnA4G/uNtHc9ihScfvAP1g569iEAW
=M++a
-----END PGP SIGNATURE-----
- [Coq-Club] refine skipping hole, S3, 10/06/2012
- Re: [Coq-Club] refine skipping hole, AUGER Cédric, 10/06/2012
- [Coq-Club] Re: refine skipping hole, S3, 10/07/2012
- Re: [Coq-Club] Re: refine skipping hole, Arnaud Spiwack, 10/08/2012
- Re: [Coq-Club] Re: refine skipping hole, S3, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Arnaud Spiwack, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, AUGER Cédric, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Pierre Courtieu, 10/09/2012
