- To: coq-club AT inria.fr
- Subject: [Coq-Club] prove forall(l : ilist 0), l = Nil ?
- Date: Wed, 17 Oct 2012 15:09:06 +0200
Hi,
I am working with length-indexed lists, as they are described in
CPDT:
Variable A : Set.
Inductive ilist : nat -> Set :=
| Nil : ilist 0
| Cons : forall n, A -> ilist n -> ilist (S n).
I have a proof where I cannot destruct some ilist, therefore I
tried to prove the following two obvious facts:
Lemma ilist_0 : forall(l : ilist 0), l = Nil.
Lemma ilist_S : forall(n : nat)(l : ilist (S n)),
exists(a : A)(tl : ilist n), l = Cons n a tl.
However, I can only prove these by using UIP_refl, ie. uniqueness
of reflexive identity proofs (full sources attached below).
Could somebody give me a hint on how to prove these lemmas
without using axioms?
I need this for the correctness prove of an decidable equality
predicate on ilists:
Fixpoint ilist_eq(a_eq : A -> A -> bool)
(n1 n2 : nat)(l1 : ilist n1)(l2 : ilist n2) : bool :=
match (l1, l2) with
| (Nil, Nil) => true
| (Cons n1 a1 l1, Cons n2 a2 l2) =>
a_eq a1 a2 && ilist_eq a_eq n1 n2 l1 l2
| _ => false
end.
Lemma ilist_eq_correct :
forall(a_eq : A -> A -> bool)(n : nat)(l1 : ilist n)(l2 : ilist n),
(forall(a1 a2 : A), a_eq a1 a2 = true <-> a1 = a2) ->
(ilist_eq a_eq n n l1 l2 = true <-> l1 = l2).
If there are no axiom-free proofs for the two lemmas above, I
would appreciate any hints on how to prove ilist_eq_correct
without axioms.
Bye,
Hendrik
ilist.v
Description: Binary data
- [Coq-Club] prove forall(l : ilist 0), l = Nil ?, Hendrik Tews, 10/17/2012
- Re: [Coq-Club] prove forall(l : ilist 0), l = Nil ?, Pierre Boutillier, 10/17/2012
- Re: [Coq-Club] prove forall(l : ilist 0), l = Nil ?, Adam Chlipala, 10/17/2012
- Re: [Coq-Club] prove forall(l : ilist 0), l = Nil ?, AUGER Cédric, 10/17/2012
