- To: Hendrik Tews <tews AT os.inf.tu-dresden.de>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] prove forall(l : ilist 0), l = Nil ?
- Date: Wed, 17 Oct 2012 19:23:33 +0200
I forgot, you might also consider the following code:
Parameter A:Set.
Require Import Bool.
Record ilist_ {S : Set} : Set :=
{ head : A
; tail : S
Fixpoint ilist (n : nat) : Set :=
match n with
| O => unit
| S n => @ilist_ (ilist n)
end.
Lemma ilist_0 : forall(l : ilist 0), l = tt.
Proof. intros []; split. Qed.
Lemma ilist_S : forall (n : nat) (l : ilist (S n)),
exists (a : A) (tl : ilist n), l = {| head := a; tail := tl |}.
Proof. intros n [a tl]; exists a; exists tl; split. Qed.
Definition ilist_eq (a_eq : A -> A -> bool)
: forall n1 n2, ilist n1 -> ilist n2 -> bool :=
fix ilist_eq n1 n2 :=
match n1, n2 with
| O, O => fun _ _ => true
| S n1, S n2 => fun (l1 : ilist (S n1))
(l2 : ilist (S n2)) =>
a_eq (head l1) (head l2) &&
ilist_eq n1 n2 (tail l1) (tail l2)
| _, _ => fun _ _ => false
end.
Lemma ilist_eq_correct :
forall(a_eq : A -> A -> bool)(n : nat)(l1 : ilist n)(l2 : ilist n),
(forall(a1 a2 : A), a_eq a1 a2 = true <-> a1 = a2) ->
(ilist_eq a_eq n n l1 l2 = true <-> l1 = l2).
Proof.
intros a_eq n l1 l2 H; induction n as [|n IHn]; simpl.
destruct l1; destruct l2; split; split.
generalize (H (head l1) (head l2)).
generalize (IHn (tail l1) (tail l2)).
clear.
intros [L1 L2].
intros [A1 A2].
split.
clear A2 L2.
destruct (a_eq (head l1) (head l2)); simpl.
intros H; generalize (L1 H); generalize (A1 (eq_refl true));
clear. destruct l1 as [h1 t1]; simpl; intros; subst.
destruct l2 as [h2 t2]; simpl.
split.
clear; intros H; exfalso.
change (match false with false => False | true => True end).
rewrite H; clear.
split.
clear A1 L1; intros; subst.
rewrite (A2 (eq_refl (head l2))); clear A2; simpl.
apply L2.
split.
Qed.
Here, ilist is not the one you used, but an isomorphic one, in which
pattern matching is easier. The final proof is long only because I show
how to proceed step by step. I can produce shorter scripts.
Le Wed, 17 Oct 2012 15:09:06 +0200,
Hendrik Tews
a écrit :
> Hi,
> I am working with length-indexed lists, as they are described in
> CPDT:
> Variable A : Set.
> Inductive ilist : nat -> Set :=
> | Nil : ilist 0
> | Cons : forall n, A -> ilist n -> ilist (S n).
> I have a proof where I cannot destruct some ilist, therefore I
> tried to prove the following two obvious facts:
> Lemma ilist_0 : forall(l : ilist 0), l = Nil.
> Lemma ilist_S : forall(n : nat)(l : ilist (S n)),
> exists(a : A)(tl : ilist n), l = Cons n a tl.
> However, I can only prove these by using UIP_refl, ie. uniqueness
> of reflexive identity proofs (full sources attached below).
> Could somebody give me a hint on how to prove these lemmas
> without using axioms?
> I need this for the correctness prove of an decidable equality
> predicate on ilists:
> Fixpoint ilist_eq(a_eq : A -> A -> bool)
> (n1 n2 : nat)(l1 : ilist n1)(l2 : ilist n2) :
> bool := match (l1, l2) with
> | (Nil, Nil) => true
> | (Cons n1 a1 l1, Cons n2 a2 l2) =>
> a_eq a1 a2 && ilist_eq a_eq n1 n2 l1 l2
> | _ => false
> end.
> n), (forall(a1 a2 : A), a_eq a1 a2 = true <-> a1 = a2) ->
> If there are no axiom-free proofs for the two lemmas above, I
> would appreciate any hints on how to prove ilist_eq_correct
> without axioms.
> Bye,
> Hendrik
- [Coq-Club] prove forall(l : ilist 0), l = Nil ?, Hendrik Tews, 10/17/2012
- Re: [Coq-Club] prove forall(l : ilist 0), l = Nil ?, Pierre Boutillier, 10/17/2012
- Re: [Coq-Club] prove forall(l : ilist 0), l = Nil ?, Adam Chlipala, 10/17/2012
- Re: [Coq-Club] prove forall(l : ilist 0), l = Nil ?, AUGER Cédric, 10/17/2012
