coq-club - [Coq-Club] Type classes and simpl
  • From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Type classes and simpl
  • Date: Mon, 29 Oct 2012 11:10:57 +0100
Hello,
I am having trouble getting the desired unfolding behavior of operational type classes with recursive instances using the simpl tactic. Let me explain this by the following example.
Consider the operational type class for a functor:
Class FMap (M : Type -> Type) :=
fmap: forall {A B}, (A -> B) -> (M A -> M B).
An instance for lists can be defined as follows:
Instance list_fmap: FMap list := fun A B f =>
fix go (l : list A) : list B :=
match l with
| nil => nil
| x :: l => f x :: go l
end.
When using this type class for proofs on lists, it does not work well because simpl does not unfold occurrences of fmap at all. Luckily, this can be fixed using the Arguments command to force to unfold simpl when the last argument is a constructor.
Arguments fmap {_ _ _ _} _ !_ /.
But still, simpl's behavior is not quite what I would like to see:
Eval simpl in (fun l => fmap S (10 :: l)).
(* fun l : list nat => 11 :: list_fmap nat nat S l *)
What we see here is that the recursive call is not folded back to the projection of the operational type class. Instead, the instance declaration itself appears. The following is what I want to see:
fun l : list nat => 11 :: fmap S l
A dirty fix is to change the definition of list_fmap such that the recursive call uses the constructor of the class.
Instance list_fmap_alt: FMap list :=
fix go A B f (l : list A) : list B :=
match l with
| nil => nil
| x :: l => f x :: @fmap _ go _ _ f l
end.
This fixes the problem, and the result of simpl uses the projection fmap for recursive calls.
Unfortunately, now the mapped function f is an argument of the fixpoint, and therefore mutual recursion is no longer possible. For example:
Inductive tree A :=
| leaf : A -> tree A
| branch : list (tree A) -> tree A.
Arguments leaf {_} _.
Arguments branch {_} _.
Instance tree_fmap: FMap tree :=
fix go A B f (t : tree A) : tree B :=
match t with
| leaf x => leaf (f x)
| branch ts => branch (fmap (@fmap _ go _ _ f) ts)
end.
will fail when the instance list_fmap_alt is declared, whereas it used to work when list_fmap was declared.
I have tried the following solutions:
* Use an autorewrite database instead of simpl. This has two problems: autorewrite does not rewrite under binders, and autorewrite is much slower than simpl.
* Put the mapped function as an argument of the functor type class
Class FMap (M : Type -> Type) {A B} (f : A -> B) :=
fmap: (M A -> M B).
This way, simpl works as expected, and mutual recursion is allowed as well. However, this is incredibly ugly, as this is not the definition of a functor. Everywhere where a functor is needed, I have to write the type class constraint as {map : forall A B (f : A -> B), FMap M f}.
Does anyone have an idea how to work around this idea? Or would it be possible to change simpl in such a way that it not only refolds fixpoints (what it is doing right now), but also refolds operational type classes?
Best,
Robbert
