- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Type classes and simpl
- Date: Mon, 29 Oct 2012 11:33:15 +0100
On 10/29/2012 11:10 AM, Robbert Krebbers wrote:
I have tried the following solutions:
* Use an autorewrite database instead of simpl. This has two problems:
autorewrite does not rewrite under binders, and autorewrite is much
slower than simpl.
I also tried using an autorewrite database to refold type class instances. This did not work well either.
Require Import List.
Class FMap (M : Type -> Type) :=
fmap: forall {A B}, (A -> B) -> (M A -> M B).
Arguments fmap {_ _ _ _} _ !_ /.
Instance list_fmap: FMap list := fun A B f =>
fix go (l : list A) : list B :=
match l with
| nil => nil
| x :: l => f x :: go l
end.
Definition list_fmap_fold A B f :
@list_fmap A B f = @fmap list (@list_fmap) A B f := eq_refl.
Hint Rewrite list_fmap_fold : fold_classes.
Lemma list_fmap_compose {A B C}
(f : A -> B) (g : B -> C) (l : list A) :
fmap (fun x => g (f x)) l = fmap g (fmap f l).
Proof.
induction l; [easy |].
simpl.
(* The goal is:
g (f a) :: list_fmap A C (fun x : A => g (f x)) l =
g (f a) :: list_fmap B C g (list_fmap A B f l) *)
autorewrite with fold_classes.
(* The goal is:
g (f a) :: fmap (fun x : A => g (f x)) l =
So, only the first occurrence has been rewritten.
rewrite list_fmap_fold.
Error: Tactic generated a subgoal identical to the original goal.
Apparently, rewrite tries to rewrite the first occurrence of list_fmap again, but fails. Note that the first occurrence of list_fmap is only partial applied, so list_fmap_fold should not even match. *)
- [Coq-Club] Type classes and simpl, Robbert Krebbers, 10/29/2012
- Re: [Coq-Club] Type classes and simpl, Robbert Krebbers, 10/29/2012
