coq-club - Re: [Coq-Club] Ill-formed recursive definition.
  • To: Paolo Tranquilli <tranquil AT cs.unibo.it>
  • Cc: AUGER Cédric <sedrikov AT gmail.com>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Ill-formed recursive definition.
  • Date: Tue, 30 Oct 2012 00:36:50 +0100
The situation gets complicated if two decreasing arguments are brought
into play:
Require Import List.
Variable A : Type.
Variable e : A.
Variable exp : forall (i : nat), list A -> list A -> A.
Variable b c : list A.
Fixpoint repeat_list (i : nat) : list nat :=
match i with
| 0 => nil
| S i' => i :: (repeat_list i')
end.
Fixpoint f (i : nat)(T: list nat) : A :=
match T with
| nil => e
| a :: T' => (fix f2 (i : nat) :=
match i with
| 0 => e
| S i' => exp i (map f2 (repeat_list i'))(map (fun i => f i T')
(repeat_list i'))
end ) i
end.
Apparently, Coq does not see that in (map f2 (repeat_list i')), f2
gets a decreasing argument,
namely i'.
Does anyone see how to make this definition type-check?
Thanks for your feedback.
On 10/23/12, Paolo Tranquilli
wrote:
> This is also an (accepted) equivalent formulation:
> Fixpoint f1 (T: list nat): Type:=
> match T with
> | nil => exp nil b c
> | _::T2 =>
> exp T2 (f1 T2) (f2 T2)
> end
> with f2 (T: list nat): Type:=
> match T with
> | nil => exp nil b c
> | _::T2 =>
> exp T2 (exp T2 (f1 T2) (f2 T2)) (f2 T2)
> end.
> 2012/10/22 AUGER Cédric
>> Le Sun, 21 Oct 2012 01:44:03 +0300,
>> Jesse Clayton
>> <j89clayton89 AT gmail.com>
>> a écrit :
>> > Hi,
>> > I wish to define function f1:
>> > Variable exp: forall (T: list nat), Type -> Type -> Type.
>> > Variable b c: Type.
>> > match T with
>> > | nil => exp nil b c
>> > | _::T2 =>
>> > end
>> > match T with
>> > | nil => exp nil b c
>> > | n::T2 =>
>> > exp T2 (f1 T) (f2 T2)
>> > end.
>> > but Coq returns "Recursive of f2 is ll-formed.". Do you have any idea
>> > how to solve this?
>> > Thanks a lot.
>> For the explanation of the error,
>> > match T with
>> > | nil => exp nil b c
>> > | n::T2 =>
>> > end.
>> In this call, the argument of the recursion (T) is not strictly smaller
>> than the one of the definition (T).
>> Maybe you mistyped it and wanted to write "(f1 T2)" instead.
>> Else, you have to explain to Coq why your recursion is well founded.
>> Variable b c: Type.
>> Definition f2_aux (f1 : list nat -> Type) : list nat -> Type:=
>> fix f2 (T : list nat) : Type :=
>> match T with
>> | nil => exp nil b c
>> | n::T2 =>
>> end.
>> match T with
>> | nil => exp nil b c
>> | _::T2 =>
>> exp T2 (f1 T2) (f2_aux f1 T2)
>> end.
>> Definition f2 : list nat -> Type := f2_aux f1.
>> In this version, all recursive calls are enough explicitely smaller for
>> the Coq system. This is accepted, although it is probably not as nice
>> as what you would have expected.
