coq-club - Re: [Coq-Club] Ill-formed recursive definition.
  • To: Jesse Clayton <j89clayton89 AT gmail.com>
  • Cc: Paolo Tranquilli <tranquil AT cs.unibo.it>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Ill-formed recursive definition.
  • Date: Tue, 30 Oct 2012 12:19:47 +0100
Le Tue, 30 Oct 2012 00:36:50 +0100,
Jesse Clayton
a écrit :
> The situation gets complicated if two decreasing arguments are brought
> into play:
You can only decrease on one argument.
> Require Import List.
> Variable A : Type.
> Variable e : A.
> Variable exp : forall (i : nat), list A -> list A -> A.
> Variable b c : list A.
> Fixpoint repeat_list (i : nat) : list nat :=
> match i with
> | 0 => nil
> | S i' => i :: (repeat_list i')
> end.
> Fixpoint f (i : nat)(T: list nat) : A :=
> match T with
> | nil => e
> | a :: T' => (fix f2 (i : nat) :=
> match i with
> | 0 => e
> | S i' => exp i (map f2 (repeat_list i'))(map (fun i => f i T')
> (repeat_list i'))
> end ) i
> end.
Your f function is needlessly complicate, I even bet it does not do
what you wish. For instance the 'a' is not even used.
> Apparently, Coq does not see that in (map f2 (repeat_list i')), f2
> gets a decreasing argument,
> namely i'.
> Does anyone see how to make this definition type-check?
> Thanks for your feedback.
You can still provide some upperbound.
Module Type Test.
Parameter A : Type.
Parameter e : A.
Parameter exp : forall (i : nat), list A -> list A -> A.
(* Parameter b c : list A.*)
End Test.
Module Test2 (T:Test).
match i with
| 0 => nil
end.
Fixpoint f (k : nat) (i : nat) (T: list nat) {struct k} : T.A :=
match T with
| nil => T.e
| a :: T' =>
let f := match k with O => fun _ _ => T.e | S k => f k end in
(fix f2 (k : nat) (i : nat) {struct k} : T.A :=
match i with
| 0 => T.e
| S i' =>
let f2 := match k with O => fun _ => T.e | S k => f2 k end
in
T.exp i (map f2 (repeat_list i'))
(map (fun i => f i T') (repeat_list i'))
end) k i
end.
End Test2.
Module Essai.
Inductive Free := Leaf : Free | Node : nat -> list Free -> list Free
-> Free. Definition A : Type := Free.
Definition e : A := Leaf.
Definition exp : nat -> list A -> list A -> A := Node.
End Essai.
Module Essai2 := Test2 Essai.
Eval compute in (Essai2.f 10000 5 (3::4::2::nil)).
There, the upper_bound for f2 is 'i' itself, and for f, you have to
compute it.
> On 10/23/12, Paolo Tranquilli
> wrote:
> > This is also an (accepted) equivalent formulation:
> > Fixpoint f1 (T: list nat): Type:=
> > match T with
> > | nil => exp nil b c
> > | _::T2 =>
> > exp T2 (f1 T2) (f2 T2)
> > end
> > with f2 (T: list nat): Type:=
> > match T with
> > | nil => exp nil b c
> > | _::T2 =>
> > exp T2 (exp T2 (f1 T2) (f2 T2)) (f2 T2)
> > end.
> > 2012/10/22 AUGER Cédric
> > <sedrikov AT gmail.com>
> >> Le Sun, 21 Oct 2012 01:44:03 +0300,
> >> Jesse Clayton
> >> a écrit :
> >> > Hi,
> >> > I wish to define function f1:
> >> > Variable exp: forall (T: list nat), Type -> Type -> Type.
> >> > Variable b c: Type.
> >> > match T with
> >> > | nil => exp nil b c
> >> > | _::T2 =>
> >> > end
> >> > match T with
> >> > | nil => exp nil b c
> >> > | n::T2 =>
> >> > exp T2 (f1 T) (f2 T2)
> >> > end.
> >> > but Coq returns "Recursive of f2 is ll-formed.". Do you have any
> >> > idea how to solve this?
> >> > Thanks a lot.
> >> For the explanation of the error,
> >> > match T with
> >> > | nil => exp nil b c
> >> > | n::T2 =>
> >> > end.
> >> In this call, the argument of the recursion (T) is not strictly
> >> smaller than the one of the definition (T).
> >> Maybe you mistyped it and wanted to write "(f1 T2)" instead.
> >> Else, you have to explain to Coq why your recursion is well
> >> founded. ===========================================
> >> Variable b c: Type.
> >> Definition f2_aux (f1 : list nat -> Type) : list nat -> Type:=
> >> fix f2 (T : list nat) : Type :=
> >> match T with
> >> | nil => exp nil b c
> >> | n::T2 =>
> >> end.
> >> match T with
> >> | nil => exp nil b c
> >> | _::T2 =>
> >> exp T2 (f1 T2) (f2_aux f1 T2)
> >> end.
> >> Definition f2 : list nat -> Type := f2_aux f1.
> >> In this version, all recursive calls are enough explicitely
> >> smaller for the Coq system. This is accepted, although it is
> >> probably not as nice as what you would have expected.
