coq-club - [Coq-Club] inversion_clear ... as
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] inversion_clear ... as
  • Date: Fri, 2 Nov 2012 15:16:09 +0000 (GMT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:Message-ID:Date:From:Reply-To:Subject:To:MIME-Version:Content-Type:Content-Transfer-Encoding; b=RRD/UG5F3WY88islc6BGL4eWHC/fMe9FNDjZbI4EbQ02tPmWgk5QIYACI+wpJPg247sEyL+0OvrnjWyXYKWq0WpTRn2ua0+9skPqaffpu/3XGfQM2Q2Wz0BDDe+cEXRQFh09iVjMuLjZ8A5KRhoV1hH9ps+GmMxg1rdnngV2YO4=;
Hello,
I'm using Coq 8.3pl1, and I'd like to use "inversion_clear ... as" to name my
hypotheses in an "intelligent" manner, that is, avoiding to fill in names for
variables/hypotheses that will be cleared by the tactic.
For instance, in the following code, I'd want my introduction pattern "[a1 b1
ORD|]" to correspond to the 2 variables and 1 hypothesis that remain in the
left subgoal, but instead I have "H4" as the name of the generated
hypothesis,and ORD is nowhere to be seen. Indeed, ORD has been used to name a
hypothesis, but it has been eliminated before the user could actually see the
result of the tactic.
Require Import Relations.
Variable A B: Type.
Variable ordA: A -> A -> Prop.
Variable ordB: B -> B -> Prop.
Inductive lex_ord: A*B -> A*B -> Prop :=
  | lex_ord_left: forall a1 b1 a2 b2,
      ordA a1 a2 -> lex_ord (a1,b1) (a2,b2)
  | lex_ord_right: forall a b1 b2,
      ordB b1 b2 -> lex_ord (a,b1) (a,b2).
Lemma wf_lex_ord:
  well_founded ordA -> well_founded ordB -> well_founded lex_ord.
Proof.
  intros Awf Bwf.
  assert (forall a, Acc ordA a -> forall b, Acc ordB b -> Acc lex_ord (a, b)).
    induction 1. induction 1. constructor; intros.
    inversion_clear H3 as [a1 b1 ORD|].
One workaround is to add a few useless names, such as [a1 b1 _A1 _A2 ORD|],
but it becomes somewhat tedious to manually check every time how many "holes"
must be filled. So I wonder if I'm missing the correct way to do it, or if
there is no way to actually "predict in advance" how many of these holes will
disappear.
