- To: Charles D <coqletsgo AT yahoo.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] inversion_clear ... as
- Date: Sun, 04 Nov 2012 10:14:04 -0500
On 11/02/2012 11:16 AM, Charles D wrote:
I'm using Coq 8.3pl1, and I'd like to use "inversion_clear ... as" to name my
hypotheses in an "intelligent" manner, that is, avoiding to fill in names for
variables/hypotheses that will be cleared by the tactic.
For instance, in the following code, I'd want my introduction pattern "[a1 b1 ORD|]" to
correspond to the 2 variables and 1 hypothesis that remain in the left subgoal, but instead I
have "H4" as the name of the generated hypothesis,and ORD is nowhere to be seen.
Indeed, ORD has been used to name a hypothesis, but it has been eliminated before the user could
actually see the result of the tactic.
Let me just add one plug for an alternative approach: always take the default names, and never write names manually. Instead, use Ltac pattern-matching to find them. More detail on the approach in CPDT:
http://adam.chlipala.net/cpdt/
- [Coq-Club] inversion_clear ... as, Charles D, 11/02/2012
- Re: [Coq-Club] inversion_clear ... as, AUGER Cédric, 11/02/2012
- Re: [Coq-Club] inversion_clear ... as, Charles D, 11/02/2012
- Re: [Coq-Club] inversion_clear ... as, AUGER Cédric, 11/04/2012
- Re: [Coq-Club] inversion_clear ... as, Adam Chlipala, 11/04/2012
