coq-club - Re: [Coq-Club] Compiling depended Coq files
  • To: Hendrik Tews <tews AT os.inf.tu-dresden.de>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Compiling depended Coq files
  • Date: Mon, 12 Nov 2012 11:52:27 -0500
Just to be clear: Below you're saying that I could give better advice, but the existing advice is still accurate, right? (And it has the benefit of working with older Proof General versions.)
On 11/12/2012 10:21 AM, Hendrik Tews wrote:
Adam
Chlipala<adamc AT csail.mit.edu>
writes:
On this subject, I recommend Section 16.4 of CPDT:
http://adam.chlipala.net/cpdt/
Section 16.4 is slightly outdated. For Proof General, load path
elements should be configured in coq-load-path. Eg
(*** Local Variables: ***)
(*** coq-load-path: ("dir_a" ("dir_b" "path_b")) ***)
(*** End: ***)
for -I dir_a -R dir_b -as path_b .
There should be no need to touch coq-prog-args.
For projects without ML modules simply check menu Coq -> Settings
-> Compile Before Require and forget about Makefiles. As I wrote
before, the details are in Section 10.2 of the user manual
(http://proofgeneral.inf.ed.ac.uk/userman).
