- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] STLC development
- Date: Thu, 15 Nov 2012 08:32:00 +0100
Am 15.11.2012 02:51, schrieb Norman Danner:
Hello list,Here are the first six (+reduction). I formalized confluence and termination using these files so I think they are sound. A lot of this has been done by Chad and Smolka.
I am looking for a development of the simply-typed lambda calculus that I could look at, as I'm having some trouble doing this on my own. I suspect my difficulties are not deep. What I'm looking for is a development along the following lines:
1. A definition of expressions (nothing complicated; just variables,
natural number constants, abstraction, and application).
2. A definition of type (nothing complicated; just N and arrow types).
3. A notion of type context.
4. A definition of 'typed G t tau', where Pi : typed G t tau means that
Pi is a derivation that t has type tau under type context G (below,
G |- t : tau).
5. A notion of substitution on expressions.
6. A proof that if G, x : sigma |- t : tau and G |- s : sigma, then
G |- t[s/x] : tau.
7. The standard full-function-space denotational semantics using nat
and -> to interpret N and arrow types, where den Pi xi is the
denotation of (the typing of) the expression t under environment
xi (i.e., really a definition of
den {G} {t} {tau} (Pi : typed G t tau) xi).
8. A proof that if Pi is a derivation of G |- t[s/x] : tau obtained
from derivations Pi_t of G, x:sigma |- t:tau and
Pi_s of G |- s:sigma, then
den Pi xi = den Pi_t (xi[x |-> den Pi_s xi]).
I can do 1-7 without much difficulty. 8 is killing me. I assume it is because I am doing something sub-optimally somewhere in 1-7.
I'm sure I'm not the first person to try to do this, and I think the most efficient way to solve my difficulties is to see it done right. I would be grateful for pointers to solutions. Thanks!
- Norman
What you mean by 7 I do not know. Do you mean a function from term to Type where [type e t N] implies [[t]] = interpret N and [type e t (T -> U)] implies [[t]] = (interpret T) -> interpret U ?
Kind regards, jonas
(** * Simply Typed Lambda Calculus in de Bruijn Representation *)
Set Implicit Arguments.
Require Export List Arith Omega.
Tactic Notation "inv" hyp(A) := inversion A ; subst ; clear A.
(** helpful tactics and lemmata on decidability of comparison *)
Ltac le_gt_destruct_s a b :=
destruct (le_gt_dec a b) ; try (exfalso ; omega).
Ltac le_gt_destruct :=
repeat destruct le_gt_dec ; try (exfalso ; omega).
Ltac lt_eq_lt_destruct_s a b :=
destruct (lt_eq_lt_dec a b) as [[|]|] ; try (exfalso ; omega).
Ltac lt_eq_lt_destruct :=
repeat (destruct lt_eq_lt_dec as [[|]|]) ; try (exfalso ; omega).
(** Abstract Syntax and Typing *)
Inductive ty : Type :=
| Nat : ty (* nat *)
| Fun : ty -> ty -> ty. (* function type *)
Inductive tm : Type :=
| tmR : nat -> tm (* reference *)
| tmL : ty -> tm -> tm (* lambda *)
| tmA : tm -> tm -> tm . (* application *)
Definition tm_eq_dec (t s : tm) : {t=s} + {t<>s}.
decide equality ; decide equality. Qed.
(** Substitution *)
(* old shift *)
Fixpoint shift' (d k : nat) (t : tm) : tm :=
match t with
| tmR x => tmR (if le_gt_dec d x then x + k else x)
| tmL T t' => tmL T (shift' (S d) k t')
| tmA t1 t2 => tmA (shift' d k t1) (shift' d k t2)
end.
(* new shift *)
Fixpoint shift d k t : tm :=
(* removed case where d = 0 for tradeoff: structure of d must be known *)
match t with
| tmR x => tmR (if le_gt_dec d x then k + x else x) (* changed x + k to k + x
for convertibility *)
| tmL T t' => tmL T (shift (S d) k t')
| tmA t1 t2 => tmA (shift d k t1) (shift d k t2)
end.
Lemma shift_O : forall d t, shift d 0 t = t.
fix 2 ; do 2 intro ; destruct t ; simpl.
destruct le_gt_dec ; tauto.
rewrite shift_O ; tauto.
do 2 rewrite shift_O ; tauto.
Qed.
Lemma shift_eq : forall d k t, shift' d k t = shift d k t.
fix 3 ; do 3 intro ; destruct t ; simpl.
rewrite plus_comm. tauto.
rewrite shift_eq ; tauto.
do 2 rewrite shift_eq ; tauto.
Qed.
Fixpoint subst (d : nat) (t s : tm) : tm :=
match t with
| tmR x => match lt_eq_lt_dec d x with
| inleft (left _) => tmR (pred x) (* x>d, free but not least
| inleft (right _) => shift 0 d s (* x=d, free and least *)
| inright _ => tmR x (* x<d, bound *)
end
| tmL T t' => tmL T (subst (S d) t' s)
| tmA t1 t2 => tmA (subst d t1 s) (subst d t2 s)
end.
Lemma shift_subst_ignore : forall s t n k l, k <= l + n -> l <= k -> subst k
(shift l (S n) s) t = shift l n s.
induction s ; simpl ; do 6 intro.
le_gt_destruct ; lt_eq_lt_destruct ; firstorder.
f_equal. apply IHs ; firstorder.
f_equal ; [ apply IHs1 | apply IHs2 ] ; firstorder.
Qed.
Lemma shift_distr : forall t n n' l l', l <= l' -> l' <= l + n -> shift l' n'
(shift l n t) = shift l (n + n') t.
induction t ; [ rename n into x | | ] ; do 6 intro ; simpl.
le_gt_destruct.
f_equal. firstorder.
tauto.
rewrite IHt ; firstorder.
rewrite IHt1 ; [ rewrite IHt2 | | ] ; firstorder.
Qed.
Lemma shift_subst_comm k n l u s : shift l k (subst (l + n) u s) = subst (l +
(k + n)) (shift l k u) s.
revert k n l. induction u ; [ rename n into x | | ] ; do 3 intro ; simpl.
le_gt_destruct ; lt_eq_lt_destruct ; simpl.
le_gt_destruct. f_equal. rewrite (S_pred x n) ; firstorder.
rewrite shift_distr ; [ f_equal | | ] ; firstorder.
le_gt_destruct. tauto.
f_equal. change (S (l+n)) with (S l + n). apply IHu.
f_equal.
apply IHu1.
apply IHu2.
Qed.
Lemma subst_distr t s u n k : subst k (subst (S (k + n)) t s) (subst n u s) =
subst (k+n) (subst k t u) s.
revert s u n k. induction t ; [ rename n into x | | ] ; do 4 intro.
unfold subst.
lt_eq_lt_destruct ;
fold subst.
tauto.
apply shift_subst_ignore ; omega.
tauto.
change n with (0+n). rewrite shift_subst_comm.
simpl. f_equal. change (S (k+n)) with (S k + n). apply IHt.
simpl. f_equal ; [ apply IHt1 | apply IHt2 ].
Qed.
Lemma shift_perm t l l' n n' : l <= l' -> shift l n (shift l' n' t) = shift
(l' + n) n' (shift l n t).
revert l l' n n'. induction t ; [ rename n into x | | ] ; do 5 intro ; simpl.
le_gt_destruct ; firstorder.
f_equal. apply IHt. omega.
f_equal.
apply IHt1. omega.
apply IHt2. omega.
Qed.
Lemma shift_subst_comm_subst t s l n u : l <= u -> shift l n (subst u t s) =
subst (u + n) (shift l n t) s.
revert s l n u ; induction t ; [ rename n into x | | ] ; do 5 intro ; simpl.
lt_eq_lt_destruct ; simpl ; le_gt_destruct ; firstorder.
apply shift_distr ; omega.
f_equal.
apply IHt. omega.
f_equal.
apply IHt1. omega.
apply IHt2. omega.
Qed.
Lemma shift_subst_distr p k n u s : shift (p+k) n (subst p u s) = subst p
(shift (S (p + k)) n u) (shift k n s).
revert p k n. induction u ; [ rename n into x | | ] ; do 3 intro.
unfold subst ; unfold shift ; fold shift ; fold subst.
lt_eq_lt_destruct ; le_gt_destruct ; simpl.
le_gt_destruct. f_equal. rewrite (S_pred x p) ; firstorder.
rewrite plus_comm. rewrite <- shift_perm.
reflexivity.
omega.
simpl. f_equal. change (S (p+k)) with (S p + k). apply IHu.
simpl. f_equal.
apply IHu1.
apply IHu2.
Qed.
Definition neutral t : Prop :=
match t with
| tmR _ => True
| tmL _ _ => False
| tmA _ _ => True
end.
Definition neutral_dec t : {neutral t} + {~neutral t}.
destruct t ; [ left | right | left ] ; firstorder. Qed.
Require Export STLC_Reduction.
Definition context := list ty.
Inductive typeC : context -> nat -> ty -> Prop :=
| typeCO g T : typeC (T::g) 0 T
| typeCS g k T T' : typeC g k T -> typeC (T'::g) (S k) T.
Inductive type : context -> tm -> ty -> Prop :=
| typeR g x T :
typeC g x T ->
type g (tmR x) T
| typeL g T t T' :
type (T::g) t T' ->
type g (tmL T t) (Fun T T')
| typeA g t1 t2 T1 T :
type g t1 (Fun T1 T) ->
type g t2 T1 ->
type g (tmA t1 t2) T.
Definition to_type T := match T with Fun _ T' => T' | _ => T end.
Definition from_type T := match T with Fun T' _ => T' | _ => T end.
Lemma type_unique g t T1 T2 :
type g t T1 -> type g t T2 -> T1 = T2.
Proof.
intros A ; revert T2 ; induction A ; intros T2 B ; inv B.
(* R *) now induction H; inv H2 ; auto.
(* L *) now f_equal ; auto.
(* A *) apply IHA1 in H2 ; apply IHA2 in H4 ; congruence. Qed.
Lemma type_R g n T a : type g (tmR n) T -> type (a::g) (tmR (S n)) T.
firstorder. do 2 constructor. inversion H. assumption. Qed.
Lemma no_type_R : forall n g T, length g <= n -> typeC g n T -> False.
fix 5. intros n g T l typ.
destruct typ.
inversion l.
apply (no_type_R _ _ _ (le_S_n _ _ l) typ).
Qed.
Lemma typing_R : forall n g T, length g > n -> typeC g n (nth n g T).
induction n.
destruct g.
intros T l. inversion l.
constructor.
destruct g.
intros T l. constructor. apply (IHn _ _ (le_S_n _ _ l)).
Qed.
Definition type_eq_dec : forall T T' : ty, {T=T'} + {T<>T'}.
Definition type_infer (t : tm) : forall g, { T | type g t T } + ~ exists T,
type g t T.
induction t ; intros g.
destruct (le_gt_dec (length g) n).
right. intros [T pT]. inversion pT. apply (no_type_R l H1).
left. exists (nth n g Nat).
constructor. apply (typing_R g Nat g0).
destruct (IHt (t::g)) as [[T typing]|notype].
left. exists (Fun t T). constructor. assumption.
right. intros [T typing]. apply notype. inversion typing.
exists T'. assumption.
destruct (IHt1 g) as [[T typl]|notypl].
destruct T.
right. intros [T typ]. inversion typ.
discriminate (type_unique typl H2).
destruct (IHt2 g) as [[T' typr]|notypr].
destruct (type_eq_dec T' T1).
left. exists T2. rewrite e in typr. apply (typeA typl typr).
right. intros [t typ]. inversion typ. apply n. rewrite
(type_unique typr H4).
apply (f_equal from_type (type_unique H2 typl)).
right. intros [T typ]. inversion typ. apply notypr. exists T0.
assumption.
right. intros [T typ]. inversion typ. apply notypl. exists (Fun T1 T).
assumption.
Defined.
Corollary type_dec (t : tm) : forall g T, {type g t T} + {~ type g t T}.
intros g T.
destruct (type_infer t g) as [[T' typ']|notyp].
destruct (type_eq_dec T T').
left. rewrite e. assumption.
right. intros typ. apply n. apply (type_unique typ typ').
right. intros typ. apply notyp. exists T. assumption.
Qed.
Lemma type_L g t T1 T2 : type g (tmL T1 t) (Fun T1 T2) -> type (T1::g) t T2.
intros typ. inversion typ. assumption. Defined.
Lemma type_A g t1 t2 T2 : type g (tmA t1 t2) T2 -> { T1 | type g t1 (Fun T1
T2) /\ type g t2 T1 }.
intros typ. destruct (type_infer t2 g) as [[T1 typr]|bogus].
exists T1. split.
inversion typ. rewrite (type_unique typr H4). assumption.
assumption.
exfalso. apply bogus. inversion typ. exists T1. assumption.
Defined.
Lemma type_A1 g t1 t2 T1 T2 : type g (tmA t1 t2) T2 -> type g t2 T1 -> type g
t1 (Fun T1 T2).
intros typ typl. inversion typ. rewrite (type_unique typl H4). assumption.
Defined.
Lemma type_A2 g t1 t2 T1 T2 : type g (tmA t1 t2) T2 -> type g t1 (Fun T1 T2)
-> type g t2 T1.
intros typ typr. inversion typ.
assert (typ_e : T1 = T0) by
apply (f_equal from_type (type_unique typr H2)).
rewrite typ_e. assumption. Defined.
Lemma inv_type_R : forall g x T D, type g (tmR x) T -> T = nth x g D.
intros g x T D ; revert g ; induction x ; intros g typ ;
inversion typ ; inversion H1.
tauto.
apply (IHx g1). apply (typeR H5).
Qed.
Lemma inv_type_L : forall g T1 t T, type g (tmL T1 t) T -> {T2| type (T1::g)
t T2 /\ T = Fun T1 T2}.
intros g T1 t T typ.
destruct (type_infer t (T1::g)) as [[T2 typt]|illtyp].
exists T2. split.
assumption.
apply (type_unique typ). constructor ; assumption.
exfalso. apply illtyp. inversion typ. eexists. apply H3.
Qed.
Definition inv_type_A := type_A.
Lemma context_ignore_l h h' g t T :
length h <= t ->
length h = length h' ->
typeC (h ++ g) t T ->
typeC (h' ++ g) t T.
Proof.
revert h h' t g. fix 1.
destruct h ; destruct h'.
tauto.
discriminate.
discriminate.
firstorder. rename t0 into t'. rewrite <- app_comm_cons.
destruct t1 ; [ inversion H | ].
constructor.
apply (context_ignore_l h).
apply le_S_n. firstorder.
firstorder.
inversion H1 ; assumption.
Qed.
Lemma context_ignore_r h h' g t T :
length g > t ->
typeC (g ++ h) t T ->
typeC (g ++ h') t T.
Proof.
revert t. induction g ; firstorder. inversion H.
destruct t.
inversion H0. constructor.
assert (H' : length g > t) by (apply gt_S_n ; firstorder).
inversion H0. constructor. apply IHg ; assumption.
Qed.
Lemma context_ignore_l_t h h' g n T :
length h <= n ->
type (h ++ g) (tmR n) T ->
type (h' ++ g) (tmR n) T.
Proof.
firstorder. constructor. inversion H1.
apply (context_ignore_l h) ;
assumption.
Qed.
Lemma context_ignore_r_t h h' g n T :
length g > n ->
type (g ++ h) (tmR n) T ->
type (g ++ h') (tmR n) T.
Proof.
firstorder. constructor. inversion H0.
apply (context_ignore_r h) ;
assumption.
Qed.
Lemma shift_l g a b n T : type g (shift a b (tmR n)) T -> a <= n -> type g
(tmR (b + n)) T.
simpl ; do 2 intro ; le_gt_destruct. tauto. Qed.
Lemma shift_r g a b n T : type g (shift a b (tmR n)) T -> a > n -> type g
(tmR n) T.
Lemma shifting g g1 g2 t T :
type (g1 ++ g) t T ->
type (g1 ++ g2 ++ g) (shift (length g1) (length g2) t) T.
Proof.
revert g2 g g1 T.
induction t ; [ induction g2 | | ] ; do 4 intro.
(* R *)
rewrite shift_O. assumption.
destruct (le_gt_dec (length g1) n).
(* variable in g1 *)
rewrite <- app_comm_cons. change (a::g2++g) with ((a::nil) ++ g2 ++ g).
rewrite app_assoc.
apply (context_ignore_l_t (a::g1)).
le_gt_destruct.
simpl. apply le_n_S. apply (le_trans _ n) ;
firstorder.
rewrite app_length. rewrite plus_comm. firstorder.
assert (type ((a::g1) ++ g) (tmR (S n)) T).
pose (IHg2 _ _ _ H).
constructor. inversion t. le_gt_destruct.
simpl ; constructor ; assumption.
(* variable in g2 *)
apply (context_ignore_r_t (g2 ++ g) _ g1) ; le_gt_destruct.
assumption.
apply (@shift_r _ (length g1) (length g2)) ; firstorder.
(* L *)
intros H. inversion H. constructor. apply (IHt g2 g (t::g1)) ;
assumption.
(* A *)
intros H. inversion H. econstructor.
apply IHt1. apply H3.
apply IHt2. apply H5.
Qed.
Lemma context_shift_down t g n T : type (t::g) (tmR (S n)) T -> type g (tmR
n) T.
intros H. inversion H. inversion H2. constructor ; assumption. Qed.
Lemma shifting_down_S gl T' gr t T :
type (gl ++ T' :: gr) (shift (length gl) 1 t) T ->
type (gl ++ gr) t T.
revert gl T' gr T ; induction t ; intros gl T' gr T typ.
simpl in typ. le_gt_destruct.
assert (typ' : type (T'::(gl++gr)) (tmR (S n)) T).
apply (context_ignore_l_t (gl ++ (T' :: nil)) (T'::gl)).
rewrite app_length. simpl. omega.
simpl. rewrite ! app_length. simpl. omega.
rewrite <- app_assoc. assumption.
apply (context_shift_down typ').
apply (context_ignore_r_t (T'::gr)) ;
assumption.
inversion typ. constructor.
rewrite app_comm_cons. apply (IHt _ T').
simpl. assumption.
inversion typ. econstructor.
apply (IHt1 _ T').
apply H2.
apply (IHt2 _ T').
apply H4.
Qed.
Lemma shifting_down gl g gr t T :
type (gl ++ g ++ gr) (shift (length gl) (length g) t) T ->
type (gl ++ gr) t T .
revert gl t T ; induction g ; intros gl t T typ.
simpl in typ. rewrite shift_O in typ. assumption.
simpl in typ.
assert (type (gl ++ a::gr) (shift (length gl) 1 t) T).
change (a::gr) with ((a::nil) ++ gr). rewrite app_assoc.
apply IHg. rewrite <- app_assoc. rewrite app_length. rewrite <-
shift_perm. rewrite shift_distr.
rewrite plus_comm. unfold app at 2. rewrite app_comm_cons. change
(1+length g) with (length (a::g)). apply typ.
omega. omega. omega.
apply (shifting_down_S gl a gr _ H).
Qed.
Lemma substitution g g' T' T s t :
type (g ++ T'::g') t T ->
type g' s T' ->
type (g ++ g') (subst (length g) t s) T.
Proof. revert g T ; induction t ; intros g T A B.
(* R *) apply (shifting_down _ (T'::nil) _). simpl. lt_eq_lt_destruct ; simpl
; le_gt_destruct.
(* g < n *) rewrite <- (S_pred _ _ l). inv A. constructor. assumption.
(* g = n *) rewrite shift_distr.
assert (type (g ++ T' :: g') (shift 0 (length g + 1) s) T
= type (nil ++ (g ++ T' :: nil) ++ g') (shift (length (@nil ty))
(length (g ++ T' :: nil)) s) T).
rewrite app_length. simpl. rewrite <- app_assoc. tauto.
rewrite H. apply shifting. clear H.
rewrite (inv_type_R T' A). rewrite app_nth2. rewrite <- e. rewrite
minus_diag. tauto.
(* g > n *) assumption.
(* L *) inv A. constructor. exact (IHt (t::g) _ H3 B).
(* A *) inv A. econstructor ; eauto. Qed.
Corollary simple_substitution g T' T s t : type (T'::g) t T -> type g s T' ->
type g (subst 0 t s) T.
change (type g) with (type (nil ++ g)).
change (type (T'::g)) with (type (nil ++ (T'::g))).
change 0 with (length (nil : context)).
apply substitution.
Qed.
Lemma preservation g t t' T :
type g t T -> step t t' -> type g t' T.
Proof. intros A B ; revert g T A.
induction B ; intros g T' A ; inv A ; eauto using type.
inv H2. eapply substitution with (g:=nil) ; eauto. Defined.
(**** Free References ****)
Inductive free : nat -> tm -> Prop :=
| freeR x : free x (tmR x)
| freeL x T t : free (S x) t -> free x (tmL T t)
| freeA x t1 t2 : free x t1 \/ free x t2 -> free x (tmA t1 t2).
Lemma type_free g t T :
type g t T -> forall x, free x t -> x < length g.
Proof. intros A ; induction A ; intros n B ; inv B.
(* R *) revert dependent x. induction g ; intros x A. now inv A.
destruct x ; inv A ; simpl ; intuition ; omega.
(* L *) apply IHA in H1. simpl in H1. omega.
(* A *) intuition ; auto. Qed.
(*** !!!! Typing ***)
Lemma empty_context g t T : type g t T -> forall l, type (g++l) t T.
revert g T. induction t as [x|T1 t IH|t1 IH1 t2 IH2] ; intros g T typ l.
apply (context_ignore_r_t nil).
apply (type_free typ).
constructor.
now rewrite app_nil_r.
destruct (inv_type_L typ) as [T2 [p1 e]]. subst.
constructor. rewrite app_comm_cons. apply IH. assumption.
destruct (inv_type_A typ) as [T1 [typ1 typ2]].
econstructor.
apply IH1. apply typ1.
apply IH2. apply typ2.
Qed.(** Reduction *)
Require Export STLC_Definitions.
Definition rel (X:Type) := X -> X -> Prop.
Inductive step : rel tm :=
| stepB T t s :
step (tmA (tmL T t) s) (subst 0 t s) (* (T.t) s -> t[0\s] *)
| stepDL T t t' :
step t t' ->
step (tmL T t) (tmL T t') (* t -> t' | (T.t) -> (T.t') *)
| stepA1 t1 t1' t2 :
step t1 t1' ->
step (tmA t1 t2) (tmA t1' t2) (* t -> t' | t u -> t' u *)
| stepA2 t1 t2 t2' :
step t2 t2' ->
step (tmA t1 t2) (tmA t1 t2'). (* t -> t' | u t -> u t' *)
(*** reflexive transitive closure ***)
Inductive star {X: Type} (R : rel X) : rel X :=
| reflexive t : star R t t
| transitive t1 t2 t3 :
R t1 t2 ->
star R t2 t3 ->
star R t1 t3.
Notation "R '*'" := (star R) (at level 20).
Lemma star_sub (R : rel tm) : forall a b, R a b -> (R *) a b.
intros a b r. econstructor.
apply r.
constructor.
Qed.
Inductive wf_star {X} (R : rel X) : nat -> rel X :=
| wf_reflexive t : wf_star R 0 t t
| wf_transitive t1 t2 t3 : forall n,
R t1 t2 ->
wf_star R n t2 t3 ->
wf_star R (S n) t1 t3.
Ltac star_transitive H := econstructor ; [ apply H | assumption ].
Lemma wf_eq : forall {X} (R:rel X) t1 t2, R* t1 t2 <-> exists n, wf_star R n
t1 t2.
intros R t1 t2. split.
intros st ; induction st.
exists 0 ; apply wf_reflexive.
destruct IHst as [n old]. exists (S n). star_transitive H.
intros [n wf_st] ; induction wf_st.
constructor.
star_transitive H.
Qed.
(* wf lemmas *)
Lemma wf_star_invr {X} (R : rel X) : forall a c n, wf_star R (S n) a c ->
exists b, wf_star R n a b /\ R b c.
fix 3. intros a c n st. destruct n.
inversion st. inversion H1. exists a. split.
constructor.
rewrite H6 in H0 ; assumption.
inversion st. destruct (wf_star_invr t2 c n H1) as [a' [wfa' pa']].
exists a'. split.
star_transitive H0.
assumption.
Qed.
Lemma wf_star_ind_right {X} (R : rel X) (P : nat -> X -> X -> Prop) :
(forall a, P 0 a a) ->
(forall a b c n, wf_star R n a b -> R b c -> P n a b -> P (S n) a c) ->
forall a b n, wf_star R n a b -> P n a b.
intros IHrefl IHstep a b n r. revert a b P IHrefl IHstep r.
induction n ; intros a b P IHrefl IHstep r.
inv r. apply IHrefl.
rename b into c. destruct (wf_star_invr r) as [b [wfr r']].
apply (IHstep _ _ _ _ wfr r' ).
apply IHn ; try assumption.
Qed.
Lemma wf_star_trans : forall {X} (R : rel X) nl nr a b c, wf_star R nl a b ->
wf_star R nr b c -> wf_star R (nl+nr) a c.
(* change order for later elegance *) intros X R nl nr a b c. revert b nr a c.
induction nl ; intros b nr a c wfl wfr.
firstorder. inversion wfl. assumption.
firstorder. destruct (wf_star_invr wfl) as [b' [wf_st pb']].
rewrite plus_Snm_nSm. apply (IHnl b').
assumption.
star_transitive pb'.
Qed.
Lemma wf_star_sub {X} (R : rel X) : forall a b, R a b -> wf_star R 1 a b.
intros a b r.
assert (st : wf_star R 0 b b) by constructor.
star_transitive r.
Qed.
(* star lemmas *)
Lemma star_invr {X} (R : rel X) : forall a b c, R a b -> R* b c -> exists b',
R* a b' /\ R b' c.
intros a b c. rewrite wf_eq. intros l [n w].
assert (wf_star R (S n) a c) by star_transitive l.
destruct (wf_star_invr H) as [b' [w' r']].
exists b'. rewrite wf_eq. split ; [ exists n | ] ; firstorder.
Qed.
Lemma star_ind_right {X} (R : rel X) (P : X -> X -> Prop) :
(forall a, P a a) ->
(forall a b c, R* a b -> R b c -> P a b -> P a c) ->
forall a b, R* a b -> P a b.
intros IHbase IHstep a b. rewrite wf_eq. intros [n wfab].
eapply (@wf_star_ind_right _ R (fun _ => P) IHbase).
intros a' b' c' n' wfa'b'. apply IHstep. rewrite wf_eq. exists n'. assumption.
apply wfab. Qed.
Lemma star_trans {X} (R : rel X) : forall a b c, R* a b -> R* b c -> R* a c.
do 3 intro. repeat rewrite wf_eq.
intros [nl wl] [nr wr]. exists (nl + nr). apply (wf_star_trans wl wr). Qed.
Lemma star_sub_R {X} (R : rel X) : forall a b, R a b -> R* a b.
do 2 intro. rewrite wf_eq. exists 1. apply (wf_star_sub _ _ _ H). Qed.
(*** helpful definitions ***)
(* symmetric of R *)
Definition symmetric X R (x y : X) : Prop := R y x.
(* R1 and R2 commute : x and z go to y -> y' goes to x and z *)
Definition commutes X (R1 R2 : rel X) : Prop := forall x z y, R2 x y -> R1 y
z -> exists y', R1 x y' /\ R2 y' z.
(* R has the diamond property *)
Definition diamond X (R : rel X) : Prop := commutes R (symmetric R).
Lemma commutativity_symmetric : forall X (R1 R2 : rel X), commutes R1 R2 ->
commutes (symmetric R2) (symmetric R1).
intros X R1 R2 c x z y r1 r2.
destruct (c z x y) as [y' pY'] ; firstorder.
Qed.
Lemma double_symmetric X R : forall x y : X, symmetric (symmetric R) x y <->
R x y.
tauto. Qed.
(* not really useful, but don't forget this *)
Goal ~ forall X (R1 R2 : rel X), commutes R1 R2 -> commutes R2 R1.
intros bad_comm.
pose (R1 := (fun _ y => y) : rel Prop).
pose (R2 := (fun x _ => x) : rel Prop).
assert (commutes R1 R2).
intros x z y _. exists True. firstorder.
destruct (bad_comm Prop R1 R2 H False False True) as [y' pY'] ;
firstorder.
Qed.
Lemma diamond_star_propagation X (R : rel X) : diamond R -> diamond (R*).
intros dR.
assert (servant : commutes (R*) (symmetric R)).
unfold commutes. fix ind 5. intros x z y sly try. revert try sly. intros [|]
sly.
exists x. firstorder. constructor.
(* create x' *)
rename t2 into z', H into sry, H0 into trz'.
destruct (dR _ _ _ sly sry) as [x' [srx slz']].
(* create y' *)
destruct (ind _ _ _ slz' trz') as [y' [srx' slz]].
exists y'. split.
star_transitive srx.
assumption.
cbv. fix master 4. intros x z y [|] try.
exists z. split.
assumption.
constructor.
rename t2 into x', H into sly, H0 into tlx'.
(* we have x', next is z' *)
destruct (servant _ _ _ sly try) as [z' [trx' slz]].
(* now the y' *)
destruct (master _ _ _ tlx' trx') as [y' [trx tlz']].
exists y'. split.
assumption.
star_transitive slz.
Qed.
Definition subst_ind R n s t t' : Prop := R (subst n t s) (subst n t' s).
Lemma type_L_unique : forall T T' t t', step (tmL T t) (tmL T' t') -> T = T'.
intros T T' t t' st. inversion st. reflexivity. Qed.
Lemma subst_induced : forall n s (t t':tm) (st : step t t'), subst_ind step n
s t t'.
(*reduction step still possible after substition?*)
fix 5. intros n s t t' st.
destruct st ; unfold subst_ind ; try (constructor ; apply subst_induced ;
apply st).
change n with (0+n). rewrite <- subst_distr. simpl. constructor.
Qed.
Lemma wf_star_subst_sub : forall n k s t t', wf_star (subst_ind step k s) n t
t' -> subst_ind (wf_star step n) k s t t'.
induction n ; do 4 intro ; unfold subst_ind.
intros H ; inversion H ; constructor.
intros H ; inversion H. econstructor. apply H1. apply IHn. assumption.
Qed.
Lemma wf_star_subst_strict : ~ forall n k s t t', subst_ind (wf_star step n)
k s t t' -> wf_star (subst_ind step k s) n t t'.
intros f.
assert (forall n, tmR (S n) <> tmR 0) by
discriminate.
assert (forall n, subst 0 (tmR (S n)) (tmR n) = subst 0 (tmR 0) (tmR n)) by
tauto.
assert (n : nat) by exact 0.
pose (k := 0).
pose (s := tmR n).
pose (t := tmR (S n)).
pose (t' := tmR 0).
assert (bad : subst_ind (wf_star step k) k s t t') by constructor.
cut (subst 0 t s = subst 0 t' s).
intro. apply (H n).
pose (worse := f 0 0 s t t' bad).
inversion worse. tauto. Qed.
Lemma wf_star_subst_induced : forall n k s t t', wf_star step n t t' ->
(* this is interesting because (subst_ind (wf_star step n)) is the stronger
set. *)
induction n ; intros k s t t' wf_b ; inversion wf_b.
constructor.
pose (subst_induced k s H0).
unfold subst_ind. econstructor. apply subst_induced. apply H0. apply IHn.
apply H1.
Qed.
Lemma wf_star_stepR : term reductions on step go to step*
not needed when this was written.
Lemma wf_star_stepL : forall k t t' T, wf_star step k t t' -> wf_star step k
(tmL T t) (tmL T t').
induction k ; do 4 intro ; inversion H ; econstructor.
(* base case for free *)
econstructor. apply H1. apply IHk. assumption.
Qed.
Lemma wf_star_stepA1 : forall k t t' u, wf_star step k t t' -> wf_star step k
(tmA t u) (tmA t' u).
Qed.
Lemma wf_star_stepA2 : forall k t u u', wf_star step k u u' -> wf_star step k
(tmA t u) (tmA t u').
econstructor 4. apply H1. apply IHk. assumption.
Qed.
Lemma star_stepL : forall t t' T, step* t t' -> step* (tmL T t) (tmL T t').
intros t t' T. rewrite wf_eq. intros [n ws]. rewrite wf_eq. exists n. exact
(wf_star_stepL _ ws). Qed.
Lemma star_stepA1 : forall t t' s, step* t t' -> step* (tmA t s) (tmA t' s).
intros t t' s. rewrite wf_eq. intros [n ws]. rewrite wf_eq. exists n. exact
(wf_star_stepA1 _ ws). Qed.
Lemma star_stepA2 : forall t s s', step* s s' -> step* (tmA t s) (tmA t s').
intros t s s'. rewrite wf_eq. intros [n ws]. rewrite wf_eq. exists n. exact
(wf_star_stepA2 _ ws). Qed.
Lemma step_shift : forall s s' l h,
step s s' ->
step (shift l h s) (shift l h s').
fix 5 ; intros s s' l h st. destruct st ; simpl.
change l with (0+l). rewrite shift_subst_distr. constructor.
constructor. apply step_shift. assumption.
Qed.
Lemma wf_star_step_shift : forall s s' k l h,
wf_star step k s s' ->
wf_star step k (shift l h s) (shift l h s').
fix 3 ; intros s s' k l h wst ; simpl ; destruct k.
inversion wst. constructor.
inversion wst. econstructor.
apply step_shift. apply H0.
apply wf_star_step_shift. assumption.
Qed.
- [Coq-Club] STLC development, Norman Danner, 11/15/2012
- Re: [Coq-Club] STLC development, Jonas Oberhauser, 11/15/2012
- Re: [Coq-Club] STLC development, Frederic Blanqui, 11/15/2012
- RE: [Coq-Club] STLC development, Nick Benton, 11/15/2012
