coq-club - Re: [Coq-Club] STLC development
  • From: Frederic Blanqui <frederic.blanqui AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] STLC development
  • Date: Thu, 15 Nov 2012 21:49:11 +0800
Hello Norman.
You can find a formalization of 1-6 in http://color.inria.fr/ using named variables (no de Bruijn indices) and explicit alpha-equivalence.
Le 15/11/2012 09:51, Norman Danner a écrit :
Hello list,
I am looking for a development of the simply-typed lambda calculus that
I could look at, as I'm having some trouble doing this on my own. I
suspect my difficulties are not deep. What I'm looking for is a
development along the following lines:
1. A definition of expressions (nothing complicated; just variables,
natural number constants, abstraction, and application).
The definition of terms is parameterized by a set of constants (you can take nat for it if you want). See http://color.inria.fr/doc/CoLoR.Term.Lambda.LTerm.html for the definitions and lemmas.
2. A definition of type (nothing complicated; just N and arrow types).
3. A notion of type context.
4. A definition of 'typed G t tau', where Pi : typed G t tau means that
Pi is a derivation that t has type tau under type context G (below,
G |- t : tau).
See http://color.inria.fr/doc/CoLoR.Term.Lambda.LSimple.html .
5. A notion of substitution on expressions.
See http://color.inria.fr/doc/CoLoR.Term.Lambda.LSubs.html .
6. A proof that if G, x : sigma |- t : tau and G |- s : sigma, then
G |- t[s/x] : tau.
See lemma tr_subs in http://color.inria.fr/doc/CoLoR.Term.Lambda.LSimple.html .
7. The standard full-function-space denotational semantics using nat
and -> to interpret N and arrow types, where den Pi xi is the
denotation of (the typing of) the expression t under environment
xi (i.e., really a definition of
den {G} {t} {tau} (Pi : typed G t tau) xi).
By "full-function-space", do you mean the set-theoretical function space F(A,B) that includes non-computable functions too? If so, the Coq space A->B is not enough.
Frederic.
8. A proof that if Pi is a derivation of G |- t[s/x] : tau obtained
from derivations Pi_t of G, x:sigma |- t:tau and
Pi_s of G |- s:sigma, then
den Pi xi = den Pi_t (xi[x |-> den Pi_s xi]).
I can do 1-7 without much difficulty. 8 is killing me. I assume it is
because I am doing something sub-optimally somewhere in 1-7.
I'm sure I'm not the first person to try to do this, and I think the
most efficient way to solve my difficulties is to see it done right. I
would be grateful for pointers to solutions. Thanks!
- Norman
