- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] coq 8.4
- Date: Tue, 20 Nov 2012 17:17:45 +0100
Hello.
I just successfully installed coq-8.4 on ./bin and wanted to try it on my development in which I've been using a pior version of Coq. Essentially, I just wanted to have a feeling of what I will need to change before fully installing (sudo make install) coq-8.4 on my machine.
I tried to run coq-8.4 but got the following error:
Connection with coqtop failed!
Command was: '/Users/gaspar/Downloads/coq-8.4/bin/coqtop' -batch
Answer was: Welcome to Coq 8.4 (November 2012)
Error: File /usr/local/lib/coq/states/initial.coq has bad magic number. It is
corrupted or was compiled with another version of Coq.
Exception was: Coq.WrongExitStatus("WEXITED 1")
I know that this 'bad magic number' error message arises whenever we try to use different versions of Coq, but in this case I don't understand where is the problem.
Why couldn't I have an old version of Coq (fully) installed and be able to run a new local installation of a newer one? Or by other words, why does starting coq-8.4 depends on /usr/local/lib/coq/states/initial.coq anyway?
Any ideas on how to fix this ?
Thank you :-)
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600 dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a terrible life choice.
- [Coq-Club] coq 8.4, Nuno Gaspar, 11/20/2012
- Re: [Coq-Club] coq 8.4, Hugo Herbelin, 11/20/2012
- Re: [Coq-Club] coq 8.4, Nuno Gaspar, 11/20/2012
