- To: Nuno Gaspar <nmpgaspar AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coq 8.4
- Date: Tue, 20 Nov 2012 18:10:45 +0100
Hi,
You're talking about a "new local installation". Did you use option
"-local" at configure time? If not, coq is not supposed to work
properly until "make install" is done.
Alternatively, you can add option
"-coqlib /Users/gaspar/Downloads/coq-8.4/"
to coqtop to force the use of your local installation directory (in
place of the expected installation repository).
Hugo Herbelin
On Tue, Nov 20, 2012 at 05:17:45PM +0100, Nuno Gaspar wrote:
> Hello.
> I just successfully installed coq-8.4 on ./bin and wanted to try it on my
> development in which I've been using a pior version of Coq. Essentially, I
> just wanted to have a feeling of what I will need to change before fully
> installing (sudo make install) coq-8.4 on my machine.
> I tried to run coq-8.4 but got the following error:
> Connection with coqtop failed!
> Command was: '/Users/gaspar/Downloads/coq-8.4/bin/coqtop' -batch
> Answer was: Welcome to Coq 8.4 (November 2012)
> Error: File /usr/local/lib/coq/states/initial.coq has bad magic number.
> It is
> corrupted or was compiled with another version of Coq.
> Exception was: Coq.WrongExitStatus("WEXITED 1")
> I know that this 'bad magic number' error message arises whenever we try to
> use
> different versions of Coq, but in this case I don't understand where is the
> problem.
> Why couldn't I have an old version of Coq (fully) installed and be able to
> run
> a new local installation of a newer one? Or by other words, why does
> starting
> coq-8.4 depends on /usr/local/lib/coq/states/initial.coq anyway?
> Any ideas on how to fix this ?
> Thank you :-)
> Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600
> dollars
> last year.
> Marge: Bart! Don't make fun of grad students, they just made a terrible life
> choice.
- [Coq-Club] coq 8.4, Nuno Gaspar, 11/20/2012
- Re: [Coq-Club] coq 8.4, Hugo Herbelin, 11/20/2012
- Re: [Coq-Club] coq 8.4, Nuno Gaspar, 11/20/2012
