- From: Justus Matthiesen <justus.matthiesen AT cl.cam.ac.uk>
- To: coq-club AT inria.fr
- Cc: stephane.lescuyer AT inria.fr
- Subject: [Coq-Club] Memory consumption issue with Containers.Maps
- Date: Tue, 27 Nov 2012 16:29:38 +0000
I've been trying to use Lescuyer's Containers library for Coq 8.4 [1].
When feeding
Require Import Containers.Sets.
Check set.
to coqtop, it dutifully reports
set : forall (A : Type) (H : OrderedType A), FSet -> Type
In contrast, when given
Require Import Containers.Maps.
Check map.
coqtop starts eating all the memory available. Is it a known bug?
Thanks,
Justus
[1] http://coq.inria.fr/pylons/contribs/files/Containers/v8.4
- [Coq-Club] Memory consumption issue with Containers.Maps, Justus Matthiesen, 11/27/2012
- Re: [Coq-Club] Memory consumption issue with Containers.Maps, David Pereira, 11/27/2012
- Re: [Coq-Club] Memory consumption issue with Containers.Maps, Justus Matthiesen, 11/27/2012
- Re: [Coq-Club] Memory consumption issue with Containers.Maps, David Pereira, 11/28/2012
- Re: [Coq-Club] Memory consumption issue with Containers.Maps, Arnaud Spiwack, 11/29/2012
