coq-club - Re: [Coq-Club] Memory consumption issue with Containers.Maps
  • From: Justus Matthiesen <justus.matthiesen AT cl.cam.ac.uk>
  • To: David Pereira <dpereira AT liacc.up.pt>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Memory consumption issue with Containers.Maps
  • Date: Tue, 27 Nov 2012 22:20:35 +0000
> Hope it helps,
It does. Thanks!
> Did you tried [Check @map]. I have not tried exhaustively with containers in
> 8.4, but I suspect the problem may be with Coq trying to find an instance
> to the definition of [map].
I may have been a bit rash to consult coq-club: dict is the analogue of set;
map is of course just the "mapping" function so it needs an FMap instance in
context.
