coq-club - Re: [Coq-Club] Performing tactics on each of the matched hypothesis
  • From: Thomas Braibant <thomas.braibant AT gmail.com>
  • To: Yucheng Zhang <yczhang89 AT gmail.com>
  • Cc: gallais <guillaume.allais AT ens-lyon.org>, AUGER Cédric <sedrikov AT gmail.com>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Performing tactics on each of the matched hypothesis
  • Date: Fri, 7 Dec 2012 11:01:35 +0100
This discussion gave me the momentum to write a small blog post about
writing tactics in OCaml. One can find it here [1].
Hope that helps
Thomas
[1] http://gallium.inria.fr/~scherer/gagallium/your-first-coq-plugin/
On Thu, Nov 29, 2012 at 3:23 AM, Yucheng Zhang
wrote:
> Thanks all for the solutions!
> On Nov 28, 2012, at 8:56 PM, Thomas Braibant
> wrote:
>> Yet, I implemented the example that was discussed in this thread, and
>> benchmarked my plugin and Guillaume's Ltac solution using the
>> following benchmark using a benchmark in which there are [n] instances
>> of [P x_i] to invert.
>> For n = 10, the Ltac code runs in 10s, the plugin in 1.5s.
>> For n = 12, the Ltac code runs in 170s, the plugin in 12s.
> I am surprised to see both codes run so slowly until I realized that 2^n
> subgoals will be generated..
  • Re: [Coq-Club] Performing tactics on each of the matched hypothesis, Thomas Braibant, 12/07/2012
