- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: coq-club Club <coq-club AT inria.fr>
- Subject: [Coq-Club] an unimportant philosophical question about coq_makefile
- Date: Fri, 7 Dec 2012 14:38:26 +0100
Hi list,
coq_makefile is not used as I imagine to will be when I rewrote a part of it.
How it was imagined :
A user contribution vertionned controlled repertory follows the scheme :
TheName
|_ src/
| |_.ml{,i,4,lib,pack} files possibly sorted in subdirectories
|_ theories/
| |_.v files sorted in subdirectories
|_ test-suite/
| |_files
|_ Make
|_ README
|_ I don't know
The "Make" file contains
-8<---
-I src
-I test-suite
-R theories TheName
-arg (* arguments to send to coqc including *)
-arg -R a_custom_path AContribIDependOn
(*-custom and customized VARIABLES *)
the exhaustive list of .{v,ml{,i,6,lib,pack}} files that are part of the
contribution one by line
-8<----
A new follower/contributor has to do "coq_makefile -f Make -o Makefile" once
after its checkout/clone/...
But then
- Custom targets are accessible directly
- Makefile is regenerated when Make changes(without disturbing the
git/svn/hg/...),
- Coqide (if it is setup to) will read the Make file and add the -I -R
-arg_argument automatically when it will start a coqtop
How it is used :
there is a Makefile in the repository that says something like
-8<----
FILES:=...
Makefile.coq: Makefile
$coq_makefile -R . $(NAME) $(FILES) -o $@
all: Makefile.coq
+$(MAKE) -f $<
-8<----
In the best case there is at the end an :
-8<---
%: Makefile.coq
+$(MAKE) -f $< $@
-8<---
the reason for that is it to hide the use of coq_makefile and allow a direct
"make" when the contrib is get from its versionned repository.
So my question is : do you have arguments to use the second setting ? and if
so how coq_makefile could be made better in that purpose (generating a
Makefile.coq that could be "-include Makefile.coq" or it is worst, you don't
care about the Make file as a project file (you use emacs anyway ()), ...) ?
Pierre B.
- [Coq-Club] an unimportant philosophical question about coq_makefile, Pierre Boutillier, 12/07/2012
- Re: [Coq-Club] an unimportant philosophical question about coq_makefile, Pierre Courtieu, 12/07/2012
