Re: [Coq-Club] Inside a branch of a match block, how do I use the assertion that the matched expression is equal to the branch's data constructor expression?
- To: abc.deaf.xyz AT gmail.com
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Inside a branch of a match block, how do I use the assertion that the matched expression is equal to the branch's data constructor expression?
- Date: Sat, 29 Dec 2012 14:51:14 -0500
On 12/29/2012 02:37 PM,
wrote:
I want to write it as follows:
Theorem nope n (p : n = O) (q : n<> O) : False.
contradict q.
exact p.
Qed.
Definition pred2 n (q : n<> O) :=
match n with
| S n => n
| O =>
let p := _ in
match nope n p q with end
end.
My problem is... what do I fill in the hole in the let clause?
I actually treat the example of dependently typed predecessor at length in Chapter 6 of CPDT <http://adam.chlipala.net/cpdt/>. The version you're looking for is one among several that the chapter works its way through.
- [Coq-Club] Inside a branch of a match block, how do I use the assertion that the matched expression is equal to the branch's data constructor expression?, abc.deaf.xyz, 12/29/2012
- Re: [Coq-Club] Inside a branch of a match block, how do I use the assertion that the matched expression is equal to the branch's data constructor expression?, Adam Chlipala, 12/29/2012
- Re: [Coq-Club] Inside a branch of a match block, how do I use the assertion that the matched expression is equal to the branch's data constructor expression?, Kristopher Micinski, 12/29/2012
- Re: [Coq-Club] Inside a branch of a match block, how do I use the assertion that the matched expression is equal to the branch's data constructor expression?, Matthieu Sozeau, 12/30/2012
