coq-club - Re: [Coq-Club] Inside a branch of a match block, how do I use the assertion that the matched expression is equal to the branch's data constructor expression?
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: abc.deaf.xyz AT gmail.com
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Inside a branch of a match block, how do I use the assertion that the matched expression is equal to the branch's data constructor expression?
  • Date: Sun, 30 Dec 2012 07:52:57 +0100
On 29 déc. 2012, at 20:37,
wrote:
> I am trying to develop a programming style that is based on preventing bad
> input as soon as possible. For example, instead of the following plausible
> definition for the predecessor function on the natural numbers:
> Definition pred1 n :=
> match n with
> | O => None
> | S n => Some n
> end.
> I want to write it as follows:
> Theorem nope n (p : n = O) (q : n <> O) : False.
> contradict q.
> exact p.
> Qed.
> Definition pred2 n (q : n <> O) :=
> match n with
> | S n => n
> | O =>
> let p := _ in
> match nope n p q with end
> end.
> My problem is... what do I fill in the hole in the let clause? My intuition
> suggests me that every clause of a `match` block must introduce an
> assumption
> that the matched expression (in this case, `n`) is equal to the clause's
> data
> constructor (in this case, `O`). In short, there must be some `assumption :
> n
> = O`. Does Coq indeed introduce such an assumption? If so, what is its name?
As explained by others, Coq does not provide you with such an equality
primitively,
but there is a standard construction to get it, which is implemented by the
Program
extension (http://coq.inria.fr/distrib/V8.4/refman/Reference-Manual028.html).
Using it you can write:
Require Import Program.
Program Definition pred2 n (q : n <> O) :=
match n with
| S n => n
| O => !
end.
The "!" notation is an abbreviations of False_rec. This program generates a
single
obligation to show [n (q : n <> 0) (Heq_n : n = 0) |- False], which is
automatically
discharged. Note that the code of [pred2] is decorated to pass this proof of
equality
around:
pred2 = fun (n : nat) (q : n = 0 -> False) =>
match n as n0 return (n0 = n -> nat) with
| 0 =>
fun Heq_n : 0 = n =>
match
match Heq_n in (_ = y) return ((y = 0 -> False) -> False) with
| eq_refl =>
fun q0 : 0 = 0 -> False =>
match q0 eq_refl return False with
end
end q return nat
with
end
| S n0 => fun _ : S n0 = n => n0
end eq_refl
Hope this helps,
-- Matthieu
