- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Guardedness checker
- Date: Wed, 09 Jan 2013 12:17:19 +0100
Hi,
The formal description of the current guardedness condition :
http://hal.inria.fr/hal-00651780
Very approximately (and the devil is in the details), it is Giménez
guardedness condition but on the weak head normal form of the body of
the fixpoint
match n with
| 0 => 0
| S x => S (foo (x - 2))
end.
in your second example)
All the best,
Pierre B
On 09/01/2013 12:09, Robbert Krebbers wrote:
> Hello,
> today I noticed that the gcd function on nat is defined as follows
> Fixpoint gcd a b :=
> match a with
> | O => b
> | S a' => gcd (b mod (S a')) (S a')
> end.
> I was quite surprised that this is accepted by Coq's guardedness
> checker. After all, it is not obvious that (b mod (S a')) is indeed
> structurally smaller than (S a').
> Also an example like
> Fixpoint foo (n : nat) :=
> match n with
> | 0 => 0
> | S x => S (foo (S x - 3))
> end.
> is happily accepted.
> This does not seem to be covered by, nor to be an obvious extension
> of, the guardedness condition as defined in Giménez' 1994 "Codifying
> guarded definitions with recursive schemes" to which (Chapter 4 of)
> the reference manual refers.
> Is there a formal description of the current guardedness condition
> that captures the above cases? Or an intuitive explanation on what it
> is doing to check these.
> Robbert
- [Coq-Club] Guardedness checker, Robbert Krebbers, 01/09/2013
- Re: [Coq-Club] Guardedness checker, Pierre Boutillier, 01/09/2013
- Re: [Coq-Club] Guardedness checker, Robbert Krebbers, 01/10/2013
- Re: [Coq-Club] Guardedness checker, Pierre Boutillier, 01/10/2013
