coq-club - [Coq-Club] A proposal for a new kind of hints in Coq
  • To: coq-club Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] A proposal for a new kind of hints in Coq
  • Date: Wed, 09 Jan 2013 15:52:27 +0200
  • Envelope-from: porton AT yandex.ru
The following is my proposal to add a new feature to Coq:
Add and remove hints to a new kind of hints databases which I call "general"
hints:
Create General Hint <db>.
[Local] General Hint <db>: <term-1>...<term-n>. (* add n terms to the DB *)
[Local] Remove General Hint <db>.
Now for a hint database named "dual_order" it can be used as follows (with $
used to refer to general hints DB):
rewrite $dual_order
would be equivalent to
rewrite <term-1>, ..., <term-n>
(if the DB "dual_order" contains <term-1>, ..., <term-n>)
and maybe likewise in other tactics, I haven't yet considered that in details.
We could also mix references to general hints databases with plain IDs like
this:
rewrite $dual_order, my_rule, $dual_category.
My proposal is not perfect. The following are the deficiencies:
1. I provide no mean to control that all hints inserted in such hints
databases are setoid equalities.
2. There should be a way to pass "references" to general hint databases, that
is variables containing a reference to a hint database. This way for example
code for both order duality and categorical duality can be shared. The best
thing for this I invented for now is double-dollar notation like:
rewrite $$dbref.
I haven't yet realized what database reference should be. Should these be
simply strings (with database names)?
Finally, if nobody is willing to implement this, I TREAT you that I will
learn ML and do it myself!
Victor Porton - http://portonvictor.org
