coq-club - Re: [Coq-Club] Effect-free admit and abstract
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Effect-free admit and abstract
  • Date: Tue, 12 Mar 2013 14:53:57 +0100
On Tue, Mar 12, 2013 at 12:40:49PM +0100, Arnaud Spiwack wrote:
> Goal True /\ True.
> Proof.
> split.
> - abstract (exact I)
> - exact I
> Defined.
Assuming you have
Lemma stuck {P Q} (h : P -> Q) (p : P) : Q. Proof. exact (h p). Qed.
The proof term would be one of the following one:
stuck (fun p => Conj p I) I
let p := I in Conj p I
The first option has an extra cost, since P is repeated twice and Q
once. The latter is cheap, but can be used only for transparent side
effects (like elimination principles).
The abstracted term I is there, so the concerns of Adam may be relevant
if you start comparing proofs. And yes, you are right, these changes
are non local. I perform them at the very end, when the proof status is
transformed into a proof term by applying the substitution to the
initial evar.
Cheers
Enrico Tassi
