- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Effect-free admit and abstract
- Date: Fri, 15 Mar 2013 15:36:37 +0100
On 13 March 2013 10:35, Enrico Tassi <enrico.tassi AT inria.fr> wrote:
Well the point is that I do
Definition f : T.
Proof.
yada-yada. (* computational part of f. *)
abstract tac. (* proof-part of f *)
Defined.
Then I use 'f' as a program. It's important that the proof parts are not evaluated. So I guess it's a hack in the same sense as the fact that opaqueness is a hack: to avoid evaluating proofs.
I just meant the interactive proof engine was really not made with this sort of transformation in mind. So it's kind of impressive that you were able to implement it.
On Wed, Mar 13, 2013 at 09:22:46AM +0100, Arnaud Spiwack wrote:Can you be more specific? What goes wrong? Is Qed too slow? Were you
> I have written a number of functions using tactics that used abstract to
> opacify their proofy parts (whithout which they simply couldn't run in an
> efficient time).
using types depending on proofs? Do you consider your practice an hack
to work around an inefficiency?
Definition f : T.
Proof.
Defined.
> I must say, I'm amazed it works.Why shouldn't it work? It is exactly what abstract does, but instead of
putting the abstracted term in the environment my code puts it in a
letin. The type of the term is the same, its body is the same, the
typing rule used to typecheck its occurrences is the same (lookup in the
context/environment for a rel/name to find its type).
Am I missing something?
- Re: [Coq-Club] Effect-free admit and abstract, (continued)
- Re: [Coq-Club] Effect-free admit and abstract, Enrico Tassi, 03/12/2013
- Re: [Coq-Club] Effect-free admit and abstract, Arnaud Spiwack, 03/12/2013
- Re: [Coq-Club] Effect-free admit and abstract, Arnaud Spiwack, 03/13/2013
- Re: [Coq-Club] Effect-free admit and abstract, Guillaume Melquiond, 03/13/2013
- Re: [Coq-Club] Effect-free admit and abstract, Enrico Tassi, 03/13/2013
- Re: [Coq-Club] Effect-free admit and abstract, Adam Chlipala, 03/13/2013
- Re: [Coq-Club] Effect-free admit and abstract, Jason Gross, 03/13/2013
- Re: [Coq-Club] Effect-free admit and abstract, Arnaud Spiwack, 03/15/2013
- Re: [Coq-Club] Effect-free admit and abstract, Adam Chlipala, 03/12/2013
