- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] A problem with subterm and rewrite tactic
- Date: Wed, 13 Mar 2013 18:06:15 -0400
Hi,
I reproduce here a message that I wrote somewhere else but I didn't get a solution:
I get stuck with the following goal in COQ :
1 subgoal
x : S1
______________________________ ________(1/1)
paths
(concat
(concat
(ap (susp_recnd base base (fun _ : Bool => loop))
(inverse (concat (meridian true) (inverse (meridian false)))))
loop) loop) loop
Remark that I don't use here display notations so it's easier to see the subterms of the current goal.
I used the following tactic: rewrite (@ap_V (susp Bool) S1 (susp_recnd base base (fun _ : Bool => loop)) N N (meridian true @ (meridian false)^)).
where ap_V is the following definition in the HoTT library:
Definition ap_V {A B : Type} (f : A -> B) {x y : A} (p : x = y) :
ap f (p^) = (ap f p)^
match p with idpath => 1 end.
But I have the following error:
Error:
Found no subterm matching "ap (susp_recnd base base (fun _ : Bool => loop))
(inverse
(inverse (meridian false))))" in the current goal.
I don't understand because it seems clearly a subterm of my current goal and I gave well-typed arguments to ap_V. Any suggestion ? I precise that I tried "Set Printing Implicit Arguments" however the error remains the same. Thanks for your help.
Best
Anthony
Best
Anthony
- [Coq-Club] A problem with subterm and rewrite tactic, Anthony Bordg, 03/13/2013
- <Possible follow-up(s)>
