coq-club - [Coq-Club] A problem with subterm and rewrite tactic
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] A problem with subterm and rewrite tactic
  • Date: Wed, 13 Mar 2013 17:53:49 -0400
Hi,
I reproduce here a message that I wrote somewhere else but I didn't get a solution:
I get stuck with the following goal in COQ :
1 subgoal
x : S1
______________________________
________(1/1)
paths
  (concat
     (concat
        (ap (susp_recnd base base (fun _ : Bool => loop))
           (inverse (concat (meridian true) (inverse (meridian false)))))
        loop) loop) loop
Remark that I don't use here display notations so it's easier to see the subterms of the current goal.
I used the following tactic: rewrite (@ap_V  (susp Bool) S1 (susp_recnd base base (fun _ : Bool => loop)) N N (meridian true @ (meridian false)^)).
where ap_V is the following definition in the HoTT library:
Definition ap_V {A B : Type} (f : A -> B) {x y : A} (p : x = y) :
  ap f (p^) = (ap f p)^
  match p with idpath => 1 end.
But I have the following error:
Error:
Found no subterm matching "ap (susp_recnd base base (fun _ : Bool => loop))
                             (inverse
                                   (inverse (meridian false))))" in the current goal.
I don't understand because it seems clearly a subterm of my current goal and I gave  well-typed arguments to ap_V. Any suggestion ? I precise that I tried "Set Printing Implicit Arguments" however the error remains the same. Thanks for your help.
Best
Anthony
