- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Partial Evar instantiation
- Date: Fri, 15 Mar 2013 12:41:42 -0400
On Fri, Mar 15, 2013 at 9:45 AM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
I'm not sure what you mean hear; my [subst] does the same thing as your [unfold]. Anyway, this is a case that I already had working the way I want it to. The problem is getting it working with dependent types, like in the first example in this email.
On 03/14/2013 04:51 PM, Jason Gross wrote:In this case, the assertion is proved easily if you add after [assert]:
Oops. Sorry, I forgot to clean up my code from a previous version of what I tried. I meant to paste
Record NT := Build_NT { CO :> forall x : nat, x = x;
HO : CO = CO }.
Goal exists x : NT, x = x.
clear.
esplit.
match goal with
| [ |- appcontext[?e] ] => is_evar e;
assert (e = @Build_NT (CO e) (HO e))
end.
apply f_equal2.
What I want to do is be able to say that [e] should start with [@Build_NT].
by (destruct e; reflexivity)
Yes, but that leaves me with
1 subgoals, subgoal 1 (ID 231)
H : ?227 = {| CO := ?227; HO := HO ?227 |}
?227 = ?227
Whereas I really want something like
H : {| CO := ?228; HO := ?229 |} = {| CO := {| CO := ?228; HO := ?229 |}; HO := HO {| CO := ?228; HO := ?229 |} |}
{| CO := ?228; HO := ?229 |} = {| CO := ?228; HO := ?229 |}
This looks like exactly the problem I was describing earlier in the thread, and the solution I proposed works:
Here's an example that works the way I want it to:
Goal forall f : nat -> nat -> nat, exists x : nat, x = x.
clear.
intro f.
esplit.
match goal with
evar (n : nat);
evar (n' : nat);
assert (e = @f n n') by (apply f_equal2; subst; reflexivity)
end.
(note that [n] and [n'] are dummy evars, which get instantiated by [reflexivity], but aren't used there-after.)
I think the problem I'm having has to do with dependent typing.
let n0 := eval unfold n in n in
match goal with
evar (n : nat);
evar (n' : nat);
let n'0 := eval unfold n' in n' in
clear n n'; assert (e = f n0 n'0) by (apply f_equal2; reflexivity)
end.
Maybe a higher-level remark will clarify what I'm looking for. Ideally, I would be delighted with a new tactic [transparent_assert], which is like [assert], but allows future goals to see the generated proof tree. I'm trying to do simpler forms of this manually, with evars.
-Jason
- [Coq-Club] Partial Evar instantiation, Jason Gross, 03/14/2013
- Re: [Coq-Club] Partial Evar instantiation, Adam Chlipala, 03/14/2013
- Re: [Coq-Club] Partial Evar instantiation, Jason Gross, 03/14/2013
- Re: [Coq-Club] Partial Evar instantiation, Adam Chlipala, 03/15/2013
- Re: [Coq-Club] Partial Evar instantiation, Jason Gross, 03/15/2013
