coq-club - [Coq-Club] Induction on lemma proof
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Induction on lemma proof
  • Date: Fri, 15 Mar 2013 13:02:20 +0100 (CET)
  • Importance: Normal
Hi All,
I have a Coq goal, which is in fact translated from Why3 system.
I tried the induction on list but could not succeed. Can some
one please hint the possible proof tactics in Coq for the
following snippet of the corresponding proof.
Parameter add_int: (list or_integer_float) -> Z -> Z.
Axiom add_int_def : forall (e:(list or_integer_float)) (j:Z),
((j <= 0%Z)%Z -> ((add_int e j) = 0%Z)) /\ ((~ (j <= 0%Z)%Z) ->
((add_int e j) = match e with
| Nil => 0%Z
| (Cons (Integer n) t) => (n + (add_int t (j - 1%Z)%Z))%Z
| (Cons _ t) => (add_int t (j - 1%Z)%Z)
end)).
(* Why3 goal *)
Theorem add_int_right : forall (e:(list or_integer_float)) (j:Z),
((0%Z <= j)%Z /\ (j < (length e))%Z) -> forall (n:Z), ((nth j
e) = (Some (Integer n))) -> ((add_int e (j + 1%Z)%Z) = ((add_int e
j) + n)%Z).
intros e j (h1,h2) n h3.
which shows the following 1 goal to be proved
1 subgoal
e : list or_integer_float
j : Z
h1 : (0 <= j)%Z
h2 : (j < length e)%Z
n : Z
h3 : nth j e = Some (Integer n)
______________________________________(1/1)
add_int e (j + 1) = (add_int e j + n)%Z
Thanks.
regards,
tk
