- From: Gregory Malecha <gmalecha AT eecs.harvard.edu>
- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] eval change
- Date: Fri, 22 Mar 2013 14:17:02 -0400
Hello --
Is there a way in Ltac to run [change] on a term? For example, I'd like to do:
let x := eval change A with B in x in ....
in order to change all of the uses of A with B.
Ideally I would be able to do this without a [match ... with context [ A ] => ... end].
- [Coq-Club] eval change, Gregory Malecha, 03/22/2013
- Re: [Coq-Club] eval change, Jason Gross, 03/22/2013
- Re: [Coq-Club] eval change, Gregory Malecha, 03/22/2013
- Re: [Coq-Club] eval change, Gregory Malecha, 03/23/2013
