coq-club - Re: [Coq-Club] eval change
  • To: gmalecha AT cs.harvard.edu
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] eval change
  • Date: Fri, 22 Mar 2013 17:09:14 -0400
Yes, I think I remember hearing that [change] is hacked together to some extent.  (For example, I think you can use question marks and holes in [change], but only if it's not inside of some other Ltac code.)
I think you could also do something like
Ltac foo x A B :=
  match x with
    | appcontext C[A] => let C' := context C[B] in
                                         foo C' A B
    | _ => x
  end.
which has the (debatable) advantage of not using continuations, but the disadvantage of using context (and of being recursive) which you said you didn't want.
What's the intended use case?
-Jason
On Mar 22, 2013 4:20 PM, "Gregory Malecha" <gmalecha AT eecs.harvard.edu> wrote:
That would work, it seems very heavy-handed though.
On Fri, Mar 22, 2013 at 3:07 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
Can do something like (untested):
Ltac do_change x A B tac :=
let H := fresh in
pose x as H;
change A with B in x;
let x' := eval unfold H in H;
clear H;
tac x'.
-Jason
On Mar 22, 2013 2:18 PM, "Gregory Malecha" <gmalecha AT eecs.harvard.edu> wrote:
Hello --
Is there a way in Ltac to run [change] on a term? For example, I'd like to do:
let x := eval change A with B in x in ....
in order to change all of the uses of A with B.
Ideally I would be able to do this without a [match ... with context [ A ] => ... end].
