- To: r.h.huijben AT student.tue.nl
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proving that something isn't a tautology
- Date: Tue, 26 Mar 2013 20:09:47 +0100
Hi Rutger,
To prove that walking women do not imply birds flying, we need one woman who
walks, and that no bird flies. So you need to add these facts to obtain a
model doing that (at the moment your domain e could even be empty).
I don't know why you set up things in the way you do, but I can imagine that
if you later want to prove things on all such first-order formulas, it is
more convenient to define them inductively, and define a function IsTrue on
top. That would also be less cumbersome to work with, than with these axioms.
Your code did not run, and some things were missing.
I added the axiom TrueA2 : forall x o, IsTrue (x o) -> IsTrue (Is_A o x),
(but a definition Is_A o x := x o would be more convenient).
I import the Setoid library in order to use <-> as a congruence relation
(to allow for the rewrite steps).
Greetings,
Dimitri
Require Setoid.
Section TuE.
Variable e t : Set.
Variable Woman Man Person Human Bird Creature: (e -> t).
Variable Fly Walk Run Move Sleep Snore Dream: (e -> t).
Variable A The No Each: (e -> t) -> (e -> t) -> t.
Variable Is_A: e -> (e -> t) -> t.
Variable Who: (e -> t) -> (e -> t) -> e -> t.
Variable Not : t -> t.
Variable And Or Imp : t -> t -> t.
Variable IsTrue: t -> Prop.
Axiom TrueImp: forall x y, (IsTrue x -> IsTrue y) <-> (IsTrue (Imp x y)).
Axiom TrueA: forall x y, IsTrue (A x y) <-> (exists o, IsTrue (Is_A o x) /\
IsTrue (y o)).
Axiom TrueA2 : forall x o, IsTrue (x o) -> IsTrue (Is_A o x).
Axiom TrueNo: forall x y, IsTrue (No x y) <-> ~(exists o, IsTrue (Is_A o x)
/\ IsTrue (y o)).
Axiom TrueEach: forall x y, IsTrue (Each x y) <-> (forall o, IsTrue (Is_A o
x) -> IsTrue (y o)).
Axiom TrueThe: forall x y, IsTrue (The x y) <-> exists o, IsTrue(y o) /\
IsTrue(Is_A o x) /\ forall z, (IsTrue(Is_A z x)) -> z = o.
Axiom TrueWho: forall x y z, IsTrue(Is_A x (Who y z)) <-> IsTrue(Is_A x y) /\
IsTrue (z x).
Axiom TrueAnd: forall x y, IsTrue (And x y) <-> (IsTrue x /\ IsTrue y).
Axiom TrueOr: forall x y, IsTrue (Or x y) <-> (IsTrue x \/ IsTrue y).
Axiom TrueNot: forall x, IsTrue (Not x) <-> ~(IsTrue x).
Variable Tweety : e.
Hypothesis WomanTweety : IsTrue (Woman Tweety).
Hypothesis WalkTweety : IsTrue (Walk Tweety).
Hypothesis PenguinsOnly : IsTrue (Not (A Bird Fly)).
Lemma aa : IsTrue (Not (Imp (A Woman Walk) (A Bird Fly))).
Proof.
rewrite -> TrueNot.
rewrite <- TrueImp.
intros H.
apply (proj1 (TrueNot (A Bird Fly)) PenguinsOnly).
apply H.
rewrite TrueA.
exists Tweety; split.
apply TrueA2.
exact WomanTweety.
exact WalkTweety.
Qed.
End TuE.
On Mar 26, 2013, at 10:30 ,
wrote:
> I'm looking for a way to prove that something is not a tautology, but not
> necesarily a contradiction either. I have the following model:
> Variable e t : Set.
> Variable A The No Each Implies: (e -> t) -> (e -> t) -> t.
> Variable Implies : t -> t -> t.
> Axiom TrueImplies: forall x y, (IsTrue x -> IsTrue y) <-> Implies x y.
> Axiom TrueA: forall x y, IsTrue (A x y) <-> (exists o, IsTrue (o ’Is A’ x)
> IsTrue (y o)).
> Axiom TrueNo: forall x y, IsTrue (No x y) <-> ~(exists o, IsTrue (o ’Is A’
> x) /\ IsTrue (y o)).
> Axiom TrueEach: forall x y, IsTrue (Each x y) <-> (forall o, IsTrue (o ’Is
> A’
> x) -> IsTrue(y o)).
> IsTrue(o ’Is A’ x) /\ forall z, (IsTrue(z ’Is A’ x)) -> z = o.
> Axiom TrueWho: forall x y z, IsTrue(x ’Is A’ (y ’Who’ z)) <-> IsTrue(x ’Is
> A’
> y) /\ IsTrue (z x).
> Axiom TrueAnd: forall x y, IsTrue (x ’And’ y) <-> (IsTrue x /\ IsTrue y).
> Axiom TrueOr: forall x y, IsTrue (x ’Or’ y) <-> (IsTrue x \/ IsTrue y).
> (Rather oversimplified version, there is a lot more going on that isn't
> relevant to the problem)
> This allows me to make terms like (A Person Walk). These terms represent
> real
> world propositions and I would like to be able to prove them when they are
> true but also be able to show that they are unproveable when they are. For
> example the term ((A Woman Walk) ’Implies’ A Bird Fly) is clearly nonsense,
> but currently I am unable to prove that.
> I have tried a number of solutions (converting either IsTrue or Implies to
> inductive types, reconstructing everything into fixpoint operators etc.) but
> those only seemed to move the problem and I am kind of stuck here, so could
> you help me with this?
> Regards,
> Rutger
- [Coq-Club] Proving that something isn't a tautology, r . h . huijben, 03/26/2013
- Re: [Coq-Club] Proving that something isn't a tautology, Daniel Schepler, 03/26/2013
- Re: [Coq-Club] Proving that something isn't a tautology, Dimitri Hendriks, 03/26/2013
- Re: [Coq-Club] Proving that something isn't a tautology, Daniel Schepler, 03/27/2013
