- To: Tobias Tebbi <ttebbi AT ps.uni-saarland.de>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Structural recusrion via minimum
- Date: Wed, 27 Mar 2013 00:13:06 +0100
Hi Tobias,
to me, this trick was new.
In Agda, one can put the height of a data structure as size index into its type, so one can make the reasoning about "structurally smaller" explicit. Here is gcd in Agda, using a symmetric difference:
{-# OPTIONS --sized-types #-}
module Gcd where
postulate
↑_ : Size → Size
∞ : Size
Size< : ..(_ : Size) → Set
max : Size → Size → Size
{-# BUILTIN SIZE Size #-}
{-# BUILTIN SIZESUC ↑_ #-}
{-# BUILTIN SIZEINF ∞ #-}
{-# BUILTIN SIZELT Size< #-}
{-# BUILTIN SIZEMAX max #-}
data Nat {size : Size} : Set where
zero : Nat
suc : {size' : Size< size} → Nat {size'} → Nat
data Either (A B : Set) : Set where
left : A → Either A B
right : B → Either A B
-- symmetric difference: returns which number was bigger, plus the difference
diff : {i j : Size} → Nat {i} → Nat {j} → Either (Nat {i}) (Nat {j})
diff zero m = right m
diff (suc n) zero = left (suc n)
diff (suc n) (suc m) = diff n m
gcd : {i j : Size} → Nat {i} → Nat {j} → Nat {max i j}
gcd zero m = m
gcd (suc n) zero = suc n
gcd {j = j} (suc n) (suc {j'} m) with diff {j = j'} n m
... | left n' = gcd {j = j} n' (suc m)
... | right m' = gcd {j = j'} (suc n) m'
(Agda development version only.)
Cheers,
Andreas
On 22.03.13 8:26 PM, Tobias Tebbi wrote:
Hi,
I would like to share a little trick to make recursive functions
structurally recursive.
Consider the gcd function, that ideally, we would like to write as
Fixpoint gcd (m n : nat) : nat :=
match m with
| 0 => n
| _ => gcd (modulo n m) m
end.
However, Coq does not accept this definition because the term (modulo n
m) is not structurally smaller than m, altough it is a smaller number.
We can circumvent this problem by constructing a term that is equal to
(mod n m) and and structurally smaller than m. All we need is the
minimum function, defined as follows.
Definition tmin m n := m - (m - n).
Using the fact that the minus from the standard library is defined in a
way that the term (m-n) is always structurally smaller or equal than m,
we have that the term (tmin m n) is strucurally smaller or equal than m.
Now the following definition of gcd works, even if modulo is left
abstract and cannot be inspected by the type checker.
Variable modulo : nat -> nat -> nat.
match m with
| 0 => n
| S m' => gcd (tmin m' (modulo n m)) m
end.
In contrast to this, the structurally recursive versions of gcd in the
Coq Standard Library (8.4) and SSReflect use special mod functions.
In proofs about functions using tmin, one just has to rewrite with the
following fact.
Lemma tmin_snd m n : n <= m -> tmin m n = n.
Proof.
unfold tmin. omega.
Qed.
This trick allows to write any recursive function that decreases a
natural number argument. It could be extended to tree-like inductive
types. In this case, instead of the minimum function, one has to search
for a given subtree in a larger tree and return it.
Please let me know if this trick has been used before.
Best,
Tobias
Andreas Abel <>< Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
- [Coq-Club] Structural recusrion via minimum, Tobias Tebbi, 03/22/2013
- Re: [Coq-Club] Structural recusrion via minimum, Andreas Abel, 03/27/2013
