- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Printing strings with newlines inside Coq
- Date: Wed, 27 Mar 2013 11:21:49 +0100
Hello Andrew and Laurent,
Maybe the same trick can have a slightly less ugly presentation:
Definition newline := String "010" "".
However, there are at least three drawbacks to this:
- The quotes are still surrounding the whole string, which is even uglier when newlines are displayed.
- The newline character is hard-coded and hence not portable (e.g. Unix-like versus Windows systems).
- It does not provide a way to define a real printing function, that could display any intermediate result during a computation (e.g. for debugging purposes). Instead, the whole function you evaluate has to return a String.
An alternative approach would be to have a "print" function as a primitive in the calculus, behaving like identity except that its reduction would trigger the display of its argument as a side effect. Printing inside Coq would then be very close to OCaml, and would probably allow a more flexible pretty printer for strings.
I think this question was raised at some point during the discussion on "computation inside Coq" of Coq workshop 2012. I'm currently working on adding some primitive operators inside Coq on integers and arrays, and I'll try to see what can be done for strings as well.
Even in the current context, maybe the syntax plugin for strings could recognize escapes.
Best,
Maxime.
On 27/03/2013 10:51, Laurent Théry wrote:
On 03/27/2013 10:31 AM, Andrew Kennedy wrote:
Coq < Open Scope string_scope.
Coq < Example s := "this is one line\n".
s is defined
An ugly fix is to dig into ascii representation :
Definition newline := String (Ascii.ascii_of_N 10) EmptyString.
- [Coq-Club] Printing strings with newlines inside Coq, Andrew Kennedy, 03/27/2013
- Re: [Coq-Club] Printing strings with newlines inside Coq, Laurent Théry, 03/27/2013
- RE: [Coq-Club] Printing strings with newlines inside Coq, Andrew Kennedy, 03/27/2013
- Re: [Coq-Club] Printing strings with newlines inside Coq, AUGER Cédric, 03/27/2013
- Re: [Coq-Club] Printing strings with newlines inside Coq, Maxime Dénès, 03/27/2013
