coq-club - Re: [Coq-Club] Printing strings with newlines inside Coq
  • To: Andrew Kennedy <akenn AT microsoft.com>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Printing strings with newlines inside Coq
  • Date: Wed, 27 Mar 2013 14:10:55 +0100
Le Wed, 27 Mar 2013 09:31:39 +0000,
Andrew Kennedy
a écrit :
> Hello
> I have a seemingly simple problem: I want to pretty-print a large
> term inside Coq, simply by writing a function
> pretty : Tm -> string
> and then be able to compute the string and look at it inside Proof
> General, or coqtop. But when using "Compute" or "Print" the string
> remains "within quotes", and the newlines remain escaped. Example:
> Welcome to Coq 8.4pl1 (January 2013)
> Coq < Require Import String.
> [Loading ML file z_syntax_plugin.cmxs ... done]
> [Loading ML file quote_plugin.cmxs ... done]
> [Loading ML file newring_plugin.cmxs ... done]
> [Loading ML file ascii_syntax_plugin.cmxs ... done]
> [Loading ML file string_syntax_plugin.cmxs ... done]
> Coq < Open Scope string_scope.
> Coq < Example s := "this is one line\n".
> s is defined
> Coq < Example ss := s++s++s++s++s++s++s.
> ss is defined
> Coq < Compute ss.
> = "this is one line\nthis is one line\nthis is one line\nthis is
> one line\n this is one line\nthis is one line\nthis is one line\n"
> : string
> I want a way of *actually* *printing* the darn thing. Is there a way?
> (Yes, I have considered simply using Notations for my Tm type, with
> format specifiers that incorporate line breaks, etc. But sometimes
> it's just easier to write a function into string, as one would do in
> ML or Haskell.)
> Cheers
> Andrew.
In Coq, there is no escape mechanism at all.
"\n" strands for '\' + 'n' (two chars).
If you want a newline, just do:
Example s :=
"this is one line
I know it can completely break your indentation, but it does not use
the "010"%char hack someone mentionned.
I do not know if it is architecture dependant (if under windows it
will give a different string).
A simple hack would be to write down your escaper your self (a string →
string which changes "\n" into newline).
I have not written a Format version of the Ocaml libraries in Coq, but
if someone is interested, I can try to write one.
And in Coq, we can even write a "format: string → Type" such that for
instance,
format "Hello %s, it is %d o'clock.\n" = string → Z → string
so that we could have a
printf : ∀ s, format s
and
Compute printf "Hello %s, it is %d o'clock.\n" "John" 8.
would return:
"Hello John, it is 8 o'clock.
