coq-club - Re: [Coq-Club] CoqIDE
  • From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] CoqIDE
  • Date: Mon, 22 Apr 2013 11:17:15 +0200
On 22/04/2013 10:49, Pierre Courtieu wrote:
> Hi, I recently added a feature for this in proofgeneral, and it could
> be very easily added to coqide too. "show ith goal", "Print" and
> "Check" have variants that do that. You can have them by the menu or
> simply add C-u before your usual keybinding.
> Adding this kind of queries to coqide would be easy: "Print with
> implicits" "Check without notation".
> For the purpose of a turorial it is probably better to have it in the
> buffer. Adding the same variant directly in Coq syntax would maybe be
> helpful.
I agree that it is very pertinent to choose this for each printing
command. Moreover, implementation of that could have the great side
effect to substitute a lot of imperrative lookup to global references
spread all over the code by a record with configuration passed to
functions ;-).
> I don't like the imposed-by-emacs way of dealing with options.
> Nobody seems to know but there is a "Coq" menu in PG :-), with a lot
> of stuff that one can click on *or bind to a shortcut key*. See "Coq
> -> options".
Amazing news, Are PG users ready for that ? Can I, at last, make these
options asynchronous ?
> P.
Pierre B.
