- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] CoqIDE
- Date: Mon, 22 Apr 2013 13:26:47 +0200
2013/4/22 Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
> Nobody seems to know but there is a "Coq" menu in PG :-), with a lot> of stuff that one can click on *or bind to a shortcut key*. See "CoqAmazing news
> -> options".
I wouldn't call that a "news", it has been there for a decade (or maybe two) :).
Can I, at last, make these
options asynchronous ?
You mean that coq should not toggle them back when backtracking in the buffer? I wouldn't mind but from a user interaction perspective I guess that similar-looking options should behave the same. All "Set/Unset" switchers should be synchronous and let us have a different keyword for asynchronous switchers. Or the other way around ("Toggle" for synchronous, and "Set/Unset" for asynchronous?). And I wouldn't mind having some options with both switchers, unless there is strong design problem... Options for printing for people who prefer that. Except if there is a really good design reason for not having that.
, Are PG users ready for that ?
For the "imperative lookups" I don't understand your problem: aren't all other options than Printing dealt the same way anyway?
Best regards,
- [Coq-Club] CoqIDE, Gert Smolka, 04/22/2013
- Re: [Coq-Club] CoqIDE, Pierre Boutillier, 04/22/2013
- Re: [Coq-Club] CoqIDE, Pierre Courtieu, 04/22/2013
