coq-club - Re: [Coq-Club] Slow QED
  • From: Thomas Braibant <thomas.braibant AT gmail.com>
  • To: Kenneth Roe <kendroe AT hotmail.com>
  • Cc: Coq-Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Slow QED
  • Date: Mon, 22 Apr 2013 21:14:43 +0200
I have run into this issue: some information that corresponds to
unfold/compute seems to be lost in the generated proof term, and this
causes trouble when type-checking the proof term at Qed. I think you
should give vm_compute a try because it will generate more appropriate
casts in the proof terms (or, if you want to use vm_compute with evars
and avoid reducing some constants, you could use my evm_compute plugin
https://github.com/braibant/evm_compute)
Below is a small example where the proof takes a few seconds, and the
proof term takes more than a hundred seconds to type check.
Require Import ZArith.
Section fold.
Variable A : Type.
Variable f : Z -> A -> A.
Fixpoint fold n acc:= match n with
| 0 => acc
| S k => fold k (f (Z.of_nat k) acc)
end.
End fold.
Open Scope Z_scope.
Definition divide x y :=
Z.modulo x y =? 0 .
Definition try n z acc :=
match acc with
| None =>
if z <? 2 then
None
else if divide n z then
Some (z,Z.div n z)
else None
| Some x => acc
end.
Definition factor n :=
match fold _ (try (Z.of_nat n)) n None with
| Some x => x
| None => (Z.of_nat n,1)
end.
Remark factorisable : forall x:nat, (let (a,b) := factor x in (a *
b)%Z) = Z.of_nat x.
Admitted.
Definition k : nat := 1111%nat. Definition ka := 101. Definition kb := 11.
Require Import String.
Check ("cbv without witnesses")%string.
Goal exists e1 e2, Z.of_nat k = e1 * e2.
intros. eexists. eexists.
rewrite <- factorisable.
set (f :=Z.mul).
Time cbv - [f]; unfold f; reflexivity. (* 4 s *)
Time Qed. (* 154 s !!! *)
Thomas
On Mon, Apr 22, 2013 at 8:50 PM, Kenneth Roe
wrote:
> I have a proof of about 100 lines. The proof itself takes a few minutes to
> process in Coq. However, it seems to hang on processing the QED at the end.
> I waited several hours and it had not completed. The proof involves
> frequent uses of "compute" to cause some fairly complex function evaluation.
> Has anyone run into this problem? I can email code to anyone who is
> interested in looking into the issue.
> - Ken
