- To: Kenneth Roe <kendroe AT hotmail.com>
- Cc: Thomas Braibant <thomas.braibant AT gmail.com>, Coq-Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Slow QED
- Date: Mon, 22 Apr 2013 22:04:11 +0200
Le Mon, 22 Apr 2013 12:56:59 -0700,
Kenneth Roe
a écrit :
> Thanks. I actually thought about using "vm_compute." The problem is
> that I have many goals that look like the following:
> ?86 = simplify (...)
> "simplify" is a fixpoint that does some sort of simplification on a
> complex term such as a program AST. What I would like to do is
> evaluate the rhs term and then instantiate the variable ?86 with the
> result. The problem is that "vm_compute" does not work with
> existentials. Is there a trick for working around this issue?
Wouldn't "reflexivity" (or split/esplit) work for that?
Why do you want to evaluate the rhs in this condition?
> - Ken
> > From:
> > Date: Mon, 22 Apr 2013 21:14:43 +0200
> > To:
> > CC:
> > I have run into this issue: some information that corresponds to
> > unfold/compute seems to be lost in the generated proof term, and
> > this causes trouble when type-checking the proof term at Qed. I
> > think you should give vm_compute a try because it will generate
> > more appropriate casts in the proof terms (or, if you want to use
> > vm_compute with evars and avoid reducing some constants, you could
> > use my evm_compute plugin https://github.com/braibant/evm_compute)
> > Below is a small example where the proof takes a few seconds, and
> > the proof term takes more than a hundred seconds to type check.
> > Require Import ZArith.
> > Section fold.
> > Variable A : Type.
> > Variable f : Z -> A -> A.
> > Fixpoint fold n acc:= match n with
> > | 0 => acc
> > | S k => fold k (f (Z.of_nat k) acc)
> > end.
> > End fold.
> > Open Scope Z_scope.
> > Definition divide x y :=
> > Z.modulo x y =? 0 .
> > Definition try n z acc :=
> > match acc with
> > | None =>
> > if z <? 2 then
> > None
> > else if divide n z then
> > Some (z,Z.div n z)
> > else None
> > | Some x => acc
> > end.
> > Definition factor n :=
> > match fold _ (try (Z.of_nat n)) n None with
> > | Some x => x
> > | None => (Z.of_nat n,1)
> > end.
> > Remark factorisable : forall x:nat, (let (a,b) := factor x in (a *
> > b)%Z) = Z.of_nat x.
> > Admitted.
> > Definition k : nat := 1111%nat. Definition ka := 101. Definition
> > kb := 11.
> > Require Import String.
> > Check ("cbv without witnesses")%string.
> > Goal exists e1 e2, Z.of_nat k = e1 * e2.
> > intros. eexists. eexists.
> > rewrite <- factorisable.
> > set (f :=Z.mul).
> > Time cbv - [f]; unfold f; reflexivity. (* 4 s *)
> > Time Qed. (* 154 s !!! *)
> > Thomas
> > On Mon, Apr 22, 2013 at 8:50 PM, Kenneth Roe
> > wrote:
> > > I have a proof of about 100 lines. The proof itself takes a few
> > > minutes to process in Coq. However, it seems to hang on
> > > processing the QED at the end. I waited several hours and it had
> > > not completed. The proof involves frequent uses of "compute" to
> > > cause some fairly complex function evaluation. Has anyone run
> > > into this problem? I can email code to anyone who is interested
> > > in looking into the issue.
> > > - Ken
- [Coq-Club] Slow QED, Kenneth Roe, 04/22/2013
- Re: [Coq-Club] Slow QED, Thomas Braibant, 04/22/2013
- RE: [Coq-Club] Slow QED, Kenneth Roe, 04/22/2013
- Re: [Coq-Club] Slow QED, AUGER Cédric, 04/22/2013
- Re: [Coq-Club] Slow QED, Frédéric Besson, 04/23/2013
