- To: coq-club AT inria.fr
- Subject: [Coq-Club] Pattern matching issue
- Date: Wed, 24 Apr 2013 20:59:44 -0500
Good Day to everyone,
Beforehand, sorry for the long message, but i needed to express this definitions
I have the following definitions:
Definition token:=Prop.
Definition D:=nat.
(*Definition of constraints*)
Inductive constraint : Type :=
This definition will be useful for this pruposes*)
basic : token->constraint
| exist : D->constraint->constraint
| conj : constraint->constraint->constraint
| impl : constraint->constraint->constraint.
Notation "% c" := (basic c) (at level 30, right associativity).
Inductive process : Type :=
tell : constraint -> process
|parallel : process -> process -> process
|ask : constraint -> process ->process
|local : D -> process -> process.
Notation "tell( c )" := (tell c) (at level 30, right associativity).
Notation "p // q" := (parallel p q) (at level 30 , right associativity).
Notation "( 'ask' c 'then' p )" := (ask c p) (at level 30, right associativity).
(* Stores reachable from a process *)
Fixpoint stores (P : process): constraint :=
match P with
tell(c)=> c
| P1 // P2 => conj (stores P1) (stores P2)
| (ask c then P1) => impl c (stores P1)
| local x P1 => exist x (stores P1)
end.
Print stores.
Fixpoint evalCons (c: constraint) : token :=
match c with
basic C1 => C1
| conj C1 C2 => (evalCons C1) /\ (evalCons C2)
| impl C1 C2 => (evalCons C1) -> (evalCons C2)
| exist x C1 => evalConsEx (exist x C1)
| exist x C1 => exists x, evalCons(C1)
end.
Now, this would be the first approach, but the evaluation of evalCons with exist x c, fails because coq is not able to infer the type of x, that could be solved doing this:
match c with
basic C1 => C1
| exist x C1 => exists x:D, evalCons(C1)
end.
However this approach is not correct, because when the application is done, it returns the following:
Print evalCons.
evalCons =
fix evalCons (c : constraint) : token :=
match c with
| %C1 => C1
| exist _ C1 => exists _ : D, evalCons C1
| conj C1 C2 => evalCons C1 /\ evalCons C2
| impl C1 C2 => evalCons C1 -> evalCons C2
end
: constraint -> token
As you can see, x was not taken in account, which is not what i want, also, i've tried the following approach:
match c with
basic C1 => C1
end
with evalConsEx (c:constraint): token:=
match x c with
However, i'm stucked on what should i do with the x, since i cannot add is as a parameter of the function, because the types do not coincide, i would appreciate if someone could give me a hint about this issue .
On the other hand, is there any way to compute a substitution, let's say i have something like
Compute(sub P x) -----I'm assuming sub is the function mentioned earlier and P is an _expression_ with a bounded variable z
and this returns something like
P[z/x]
or should i define it?
Again, a hint or some literature about it would be appreciated.
Thank You
Mauricio Alejandro CanoPontificia Universidad Javeriana
Facultad de Ingeniería
Ingeniería de Sistemas y Computación
- [Coq-Club] Pattern matching issue, mauricio cano, 04/25/2013
