coq-club - Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?
  • To: Bai Wei <baiweiyj AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?
  • Date: Wed, 24 Apr 2013 12:42:16 -0400
Hi,
After you extract the raw proof term from your Ltac script (to check with
Coq's kernel), you will also need to extract all the definitions that your
proof may use from the standard library and distribute them as your theory as
well. I don't know if there are any tools to automate this process. If you
really want to use Coq (with tactics) as a proof generator. This will be the
only way to do it. It will be certainly harder to translate Coq terms into
simpler type theories like LF (twelf) than the other way around.
If you can use other proof generators (like SAT/SMT solvers), there are more
options because SAT/SMT are smaller fixed logics and they have been encoded
in several different proof systems.
-- Duckki
On Wednesday, April 24, 2013 at 6:35 AM, Bai Wei wrote:
> Hi. I want to implement Foundatinal proof carrying code (FPCC) paradigm.
> Does Coq proof checker can be used as a proof checker in FPCC? Many Thanks!
> Cheers,
> Wei Bai
