coq-club - Re: [Coq-Club] Finite set to list
  • From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Finite set to list
  • Date: Fri, 26 Apr 2013 08:17:57 +0800
Hello.
If you are only interested in finite sets, you can also try the FSet module. See the FSetUtil module of the CoLoR library to see how to use it. Definitions and lemmas without proofs can be seen on http://color.inria.fr/doc/CoLoR.Util.FSet.FSetUtil.html .
Regards,
Frédéric.
Le 25/04/2013 21:21, Vincent BENAYOUN a écrit :
Hi everybody,
I am using the Coq standard library for set.
I consider :
- Coq.Sets.Ensembles
- Coq.Sets.Finite_sets
How can I write a function which take a finite set and return a list of its elements ?
I have written the following code which obviously doesn't work.
How can I fix it ?
Require Import Ensembles.
Require Import Finite_sets.
Fixpoint finite_set_to_list (s:Ensemble label) (P:Finite _ s) : list label :=
match P with
| Empty_is_finite => nil
| Union_is_finite s' P' x H => cons x (finite_set_to_list s' P')
end.
Thanks in advance,
Vincent
