- From: Christian Doczkal <doczkal AT ps.uni-saarland.de>
- To: Vincent BENAYOUN <benayoun.vincent AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Finite set to list
- Date: Thu, 25 Apr 2013 16:13:45 +0200
Hi
In order to define such a function, you need to assume an Axiom.
If you Import Coq.Logic.ClassicalEpsilon you get an epsilon operator
satisfying:
Definition epsilon_spec (A : Type) (i:inhabited A) (P : A->Prop) :
(exists x, P x) -> P (epsilon i P)
Then you can first prove (by induction on Finite) that such a list exists for
every set and afterwards use the epsilon operator to obtain such a list.
Regards
Christian
On 25.04.2013, at 15:21, Vincent BENAYOUN
wrote:
> Hi everybody,
> I am using the Coq standard library for set.
> I consider :
> - Coq.Sets.Ensembles
> - Coq.Sets.Finite_sets
> How can I write a function which take a finite set and return a list of its
> elements ?
> I have written the following code which obviously doesn't work.
> How can I fix it ?
> Require Import Ensembles.
> Require Import Finite_sets.
> Fixpoint finite_set_to_list (s:Ensemble label) (P:Finite _ s) : list label
> match P with
> | Empty_is_finite => nil
> | Union_is_finite s' P' x H => cons x (finite_set_to_list s' P')
> end.
> Thanks in advance,
> Vincent
- [Coq-Club] Finite set to list, Vincent BENAYOUN, 04/25/2013
- Re: [Coq-Club] Finite set to list, AUGER Cédric, 04/25/2013
- Re: [Coq-Club] Finite set to list, Christian Doczkal, 04/25/2013
- Re: [Coq-Club] Finite set to list, Marco Servetto, 04/29/2013
- Re: [Coq-Club] Finite set to list, Daniel Schepler, 04/30/2013
- Re: [Coq-Club] Finite set to list, Daniel Schepler, 04/25/2013
- Re: [Coq-Club] Finite set to list, Pierre Courtieu, 04/25/2013
- Re: [Coq-Club] Finite set to list, Frédéric Blanqui, 04/26/2013
